It is currently Sun Jul 20, 2025 10:24 am
 Post subject: Alternator problem
PostPosted: Sat Jun 17, 2006 1:09 pm
I've just fitted a Bosch Alternator from a N13 Pulsar, and have it wired up as per instructions, but the problem is it doesn't seem to be charging. I wasn't able to get it tested from where I got it from, but it is under warranty
When I put the voltmeter across the B+ termianl with the wire disconnected from the solenoid, I only get a reading of .7V and goes up to 1.5 when I rev it,
Would a new regulator fix this?
 Post subject: undo some wires
PostPosted: Thu Jun 22, 2006 10:35 pm
Take off the wires where it feeds the loom....and see what the voltage reads then....you may have a short somewhere.
Double check the way you have wired it.
Users browsing this forum: Scoop and 82 guests
