It is currently Sun Jul 20, 2025 8:32 pm
 Post subject: evrything prep
PostPosted: Fri Jun 23, 2006 2:47 pm
Die Die Die!!
with my new project i want to know in what order i should go about sanding it...
ok im going to sand back the car with 80 grit.. then primer it...in 2 pac primer (and deaden on the inside and underside of the car) i was wondering how many times i should sand it back.. and with what grade paper.. thats all.. for a reasonably good prep..
also i want to paint the engine... do you have to spereate the block from the gearbox to paint it ?... and would you just use degreaser and prepsole to prep for painting ?
PostPosted: Fri Jun 23, 2006 4:16 pm
Buy this:
http://cgi.ebay.com.au/BOOK-How-To-Pain ... dZViewItem[url]
explains everthing you want/need to know
PostPosted: Fri Jun 23, 2006 4:19 pm
buy a random orbital sander, itll save you days! I WISH ID HAD ONE EARLIER!
PostPosted: Fri Jun 23, 2006 6:29 pm
http://www.autobody101.com/forums/
http://www.autobodystore.com/
--->>>http://www.users.bigpond.net.au/brigidine/JAM/paint.htm<<<---
reading is your friend my friend ;)
PostPosted: Fri Jun 23, 2006 6:46 pm
80grit might be a bit coarse for what you need!!
i think that 120 would be the roughest paper to use!!
can anyone shed any light on this?
Rohan
1964 MORRIS 850 - POST ZOMBIE APOCALYPSE CAFE RACER INSPIRED.
https://spotify.link/D0P4KtIP2yb
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
1.3:1 Roller tip rockers
Stupid high CR
PostPosted: Fri Jun 23, 2006 7:43 pm
Die Die Die!!
SSwanab rekons his boss (paintshop) said to use 80...
PostPosted: Fri Jun 23, 2006 8:29 pm
yer 80 grit works a treat used it on mine :wink:
PostPosted: Fri Jun 23, 2006 8:34 pm
OK, cool, i stand corrected!!! i will shut up!!! :oops:
As you were lads!!!
Rohan
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
Stupid high CR
PostPosted: Fri Jun 23, 2006 9:19 pm
:D
PostPosted: Fri Jun 23, 2006 9:46 pm
80 is too coarse and will show alot of imperfections - start off with 80 and work your way up to around 400 or 600
people suggest between 400 and 600 on the autobody101 forums and jam used 400wet/dry
PostPosted: Fri Jun 23, 2006 10:02 pm
if u got to sand it back to bare metal then its fine when u prime it then sand it u use 240 and so on
PostPosted: Fri Jun 23, 2006 10:33 pm
Yeh use the 80 grit to get it down to bare metal...as far as i know...i didnt have to, so less knowledge there.
-But if there isnt too many layers of paint, use something like 120 to rub it back. This allows the primer to stick a little nicer...ur not taking all the paint off, only the glossy feel to it.
If u do use a courser grit paper, u might have to use less thinners in the primer, for a thicker fill. gets into the lil scratches.
ONCE primer is on:
- THICK / ROUGHER primer coat, sand down with 600 or so..
If you use a wet coat of primer, use something like 800.
DONT FORGET.... Before you go to put any paint on, use wax and grease romover on a clean rag and wipe down the car.
1978 Leyland clubman S.
PostPosted: Sat Jun 24, 2006 12:37 am
paint stripper and wire wheel along with a orbital sander
80 grit will be ok jsut go over it with a 120 then a ... etc
what about soda blasting seems to work well
PostPosted: Sat Jun 24, 2006 7:26 pm
You guys are lazy and farken butchers using 80 grit!!! :x
That is so coarse!!
You might get things done quick, and think it looks pretty sweet, but when you get that gloss on it at the end, you might end up seeing scratch marks galore in your finished job.
If you actually care about what you are doing, and the job at hand, don't even think about using that to remove paint.
It might be acceptable to shape filler, but that would be the only time I personally would use it.
Website: www.justanothermini.com
PostPosted: Sat Jun 24, 2006 10:53 pm
Die Die Die!!
cheers thats what i thought.... 120 it is...
Users browsing this forum: Scoop and 97 guests
