It is currently Mon Aug 04, 2025 10:29 am
PostPosted: Mon Jul 03, 2006 8:52 pm
Hi All,
If a Cooper S engine has been restamped how can still id the engine to be sure it is a genuine MK1 or MK2 Cooper S motor? :?
67 Deluxe under going full resto
PostPosted: Mon Jul 03, 2006 8:57 pm
The Cooper S motor is the only 1275 with side covers over the tappet chest. 8)
If it has side covers and it is a 1275 it must be a Cooper S.
PostPosted: Mon Jul 03, 2006 9:12 pm
thanks for that. :)
PostPosted: Mon Jul 03, 2006 9:32 pm
Mk1s had a thin bottom flange, Mk2s had a thick one. usually... :lol:
PostPosted: Mon Jul 03, 2006 9:37 pm
I have found that with most Cooper S with the engine number ground off that if you look very carefully you can usually make out 12YD/Ta/H***** 8)
PostPosted: Mon Jul 03, 2006 9:38 pm
.... except those boasting 8AM/U/H... seen a few now!
PostPosted: Mon Jul 03, 2006 9:41 pm
The owner can only decify "cfmsh". Never heard of that combo. No tappets covers so not a cooper anyway.
PostPosted: Tue Jul 04, 2006 9:31 am
:wink:
MK 1 block casting number is AEG312. Located on rear of block just above flange and below oil gallery to oil pump.
RonR
