It is currently Thu Jul 31, 2025 7:52 pm
Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Thu Aug 24, 2006 6:59 pm
Wow, only wish I could have someone liek you in WA...
Ian - My Ve SSV Ute - Looking for a Mini
PostPosted: Thu Aug 24, 2006 9:08 pm
High heel ninja
I supose i could blunge a ride up with Aaron for the day & help out, mind you i don't know much about pulling motors out of minis!
Doogie
PostPosted: Thu Aug 24, 2006 9:14 pm
ok im here....
well my old man aint really that old ..... its just a nickname sort of thing.. lol
the 16th is fine with us.....
just need to know numbers before hand to help with preparation for the bbq....
i am able to get all the things such as gaskets.... just let me know.....
there are plenty of caravan parks around toronto........ dont worry....
thanks for the help everyone, i truely am soooooo thankfull
PostPosted: Thu Aug 24, 2006 10:56 pm
Doogie
I am truely pleased you are coming. That means betwenn Aaron, yourself and the little I know we are in a good position to get the job done quickly, safely and efficiently as well as teaching anyone else who turns up. This is truely great stuff and makes me pround of the Mini Car Club and the general mini fraternity.
I will bring clutch tools, my general tools, jack stands, ball joint breaker and the engine crane. I will also bring my trolley jack but is not the big high lift type - just a father day present K-mart type. I also have a tension wrench and an engine lifting bracket made by Kevin (1310/71)
Tait - we are doing good here - you need a head gasket kit (VRS kit), a conversion gasket kit, Heater bypass hose, clutch seal and timing case seal. Also a thing of aviation gasket goo , oil filter (the filter on the motorhere is a canister type -NOT a spin on - but we can change it if yours is the spin and the bolts come out cleanly) We also need oil, coolant and while we are at it - spark plugs and a set of points to suit your dizzy. A set of engine mounts would be good also if you can afford it. Also if your radiator hoses are soft, swollen and spongy - now is the time to change them.
I have already found someone to feed our animals so my wife and I will come to Newcastle friday afternoon - can you give some details of the caravan parks locally please ? - so we can have an early start saturday.
I will keep track of numbers and names for the very much welcomed BBQ.
Doogie, Aaron - can you think of anything missed ?????
Sorry about the latenessof the response - been at a bush fire brigade meeting
PostPosted: Thu Aug 24, 2006 11:09 pm
I always find keeping a few extra thermostat housing gaskets handy helps
Have a think about what is on your block, and what you will need to to take off his - ie flywheel puller for example?
Is a fuel pump gasket included in the conversion set?
KB
PostPosted: Thu Aug 24, 2006 11:18 pm
Bring them up with you kev - the thermostat gaskets etc
Yep - flywheel puller is part of the clutch tools
Fuel pump gasket - no its not part of the kit - the motor in question is actually the one out of your friends white clubby van. I replaced the burnt exhaust valve and it ran fine just hasnt been run since i pulled the engine from that van. When you next see him tell him where the motor is going, he hould be pleased. btw his gear box is sitting under my 1310 in the kermit
keep thinking of what we need fellas - this is an exercise in getting a car going economically so no ARP bolt suggestions *s* though
PostPosted: Fri Aug 25, 2006 6:51 am
Would if I could. The 16th I'll be in Melbourne (MotoGP weekend at Phillip Is).
Hopefully you now know a bit more about what engine/gearbox/dizzy/carb etc Harvey69 has in the car already - ie he won't need points if he has a pulsar dizzy etc.
KB
PostPosted: Fri Aug 25, 2006 7:52 am
What a great idea! :) :) Big smiley stamp for you all. Its great to see the more learned amoungst us passing (that aint me) passing on the skills that cant seem to learn anywhere else... :)
Now Cushie I dont think what you wanted to teach them requires power tools, but I could be mistaken :shock:
PostPosted: Fri Aug 25, 2006 8:23 am
High heel ninja
Mike, thought of something you missed, Dancing girls, we need dancing girls :lol:
I'll bring up my good aluminium trolley jack & my cordless impact gun, it will make it fun fun fun.
Doogie
PS I still have to get permission to go from the higher authority.
PostPosted: Fri Aug 25, 2006 8:32 am
Doogie
I hope you kept the dancing girls from Minister for Home Affairs - could be in the poo!!
At the moment I am still good to go(even if just for comic relief and having someone there to pull the piss out of... :lol: )
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Fri Aug 25, 2006 9:54 am
Doogie
dancing girls - hmmm.. I will pass that to Gina to organise and see what and who she comes up with.
Rob - its great your coming - dont worry you will get some grease on your hands even if its just from shaking hands.
PostPosted: Fri Aug 25, 2006 2:16 pm
If you're replacing the engine mounts don't buy the ones with the captive nuts, because they won't line up and you'll wate hours trying. Best thing to do is weld nuts onto the standard ones or even your older ones to make things easier.
PostPosted: Fri Aug 25, 2006 5:35 pm
Totally agree on the engine mounts - we can live with the normal ones
But as an aside - some one who is a welder could make quite a small fortune here if they purchased supplies of engine mounts and nuts and sat quietly one afternoon carefully MIGging the nuts on.
PostPosted: Fri Aug 25, 2006 5:40 pm
Last time i pulled my motor out and back in it took. 5 mins a side to line up and bolt in the botttom mounts. All comes down to a good strong screwdriver and a pair of pointy nose pliers. Yes nuts welded on does mae it easier, but you also have to be careful not to ruin the thread on the nut when getting the mounts in place.
One thing to keep in mind is that by using two new mounts it causes all sorts of issues getting the bugger in. New ones are very tight. My Solution was to put one new one in on the rad side and the best of the old in the clutch side. As the clutch will probably come out before the radiator, I would replace the clutch side one when i need to do the clutch again. Makes life easy, and much less stressful.
Aaron
PostPosted: Fri Aug 25, 2006 5:43 pm
High heel ninja
AAAHHHH Grasshopper Ruig, you are learning well my student.
Doogie
Users browsing this forum: Bing [Bot], cruiser23 and 86 guests
