It is currently Wed Jul 30, 2025 10:17 am
PostPosted: Sun Aug 27, 2006 5:06 pm
Can't reply to the other thread on this Q, it locks me out.... :evil:
Try either CP4 needles, or #6. We're using the 6s on my wife's car now, which is very similar specs-
1293cc, twin HS4s, Tighe 104 cam, Corolla rockers, rimflow valves, Perry 3-1 freeflow exhaust, Lukey muffler. C/R is about 9.4:1.
Air filters are Ramflos, with UniFilter oiled foam pads.
A/F ratio is spot on all the way up. :wink:
<edit> it was too rich just coming off idle, so we put ATF in the dampers and it's OK.
PostPosted: Sun Aug 27, 2006 5:45 pm
Thanks,
I will give that a go and see how it goes when i get it dynoed.
Any ideas on the dash pot springs?
76 1275 Leyland S
PostPosted: Sun Aug 27, 2006 6:34 pm
I'm running what was in there, they are blue or red, I can't tell which... colour has gone.... :wink:
 Post subject: Twins
PostPosted: Sun Aug 27, 2006 6:38 pm
What jap car had twin SUs...Datto SSS :?: ..... signed Mental Block :)
 Post subject: Re: Twins
PostPosted: Sun Aug 27, 2006 6:55 pm
I think so but they were Hitachi SUs.. not identical to the real deal.
PostPosted: Sun Aug 27, 2006 7:06 pm
[quote="drmini in aust"][quote="9YaTaH"]What jap car had twin SUs...Datto SSS :?: ..... signed Mental Block :)[/quote]
I think so but they were Hitachi SUs.. not identical to the real deal.[/quote]
Yeahbut....Ronnimac....are you saying you got twin SUs off a jap car or they were twin SUs fitted to a Jap car as standard equipment :?: :D
PostPosted: Sun Aug 27, 2006 11:26 pm
They were from a 260Z and are ISO brand.
They look very similar except they have four bolts to hold the Dash Pot down and four bolts on the top of the float bowl.
I have had to modify them by fitting 3 screw dash pots from a genuine SU as original ones were pitted on the piston and shaft. I did this by using one of the existing threads and tapping 2 new ones. Also the float bowls have rubber mounts around the shaft that holds them onto the carby to stop some of the shock from traveling into the bowl.
76 1275 Leyland S
 Post subject: Thanks..
PostPosted: Sun Aug 27, 2006 11:38 pm
[quote="ronniemac"]They were from a 260Z and are ISO brand.
I have had to modify them by fitting 3 screw dash pots from a genuine SU as original ones were pitted on the piston and shaft. I did this by using one of the existing threads and tapping 2 new ones. Also the float bowls have rubber mounts around the shaft that holds them onto the carby to stop some of the shock from traveling into the bowl.[/quote]
Sometimes.....Ya learn something everyday.....thanks 8)
Users browsing this forum: No registered users and 65 guests
