It is currently Sun Jul 20, 2025 9:32 pm
 Post subject: Rubber Cones
PostPosted: Wed Aug 30, 2006 11:01 pm
Hi yall
I have been quoted $25 each for good second hand rubber cones. Do you think this is reasonable?
blokeinamoke wrote:
PostPosted: Wed Aug 30, 2006 11:08 pm
I'm not stalking you... I swear..... $25 is reasonable - if they're good.... but you really need to compare them with a rooted one to be sure. They're $100 each new
PostPosted: Wed Aug 30, 2006 11:22 pm
Hijack...
How often should cones be replaced?
End Hijack...
Thanks for comming :-P
1975 Hairy Lime/White Clubby
PostPosted: Thu Aug 31, 2006 10:41 am
Thorlek wrote:
Hijack...
End Hijack...
depends on how much abuse they've had.... there would be 850's getting around with their original ones in from 46 years ago, but I've replaced ones on a '78 clubman that were absolutely shagged..
 Post subject: re rubber cones
PostPosted: Thu Aug 31, 2006 5:04 pm
yeah I seen them advertised for $125, I have both subbies outa the car so I can take in the crap ones from the front and the good ones from the back for comparison. Unless I get a second hand set that a better than the back ones I will put the old rear ones in the front and the good secondhandies in the rear. I was amazed at the difference in the size of the front and rear. If you had plenty of time on your hands it would be almost worth swapping them front to rear every so often. But it is a massive job like I said you would need time.
re: stalking
I dont mind its quite flattering :D
blokeinamoke wrote:
Users browsing this forum: Majestic-12 [Bot] and 82 guests
