It is currently Mon Aug 04, 2025 5:50 am
PostPosted: Wed Nov 01, 2006 8:17 pm
I got my new minator 6x10s with dunlop formula R's on tonite, they look awesome! Only problem is that at the front on the disc's they stick out my my archs by about 3/8 inch or so. Not much but from looking from directly behind you can see the widest part of the tyre out, the top is just in. My rear tyres are perfect fit. I'm jsut gonna use these wheels for track and show, so I don't fear getting defected but I don't want to risk it too much. What have other people done in this situ? I can't re-do my flares easy as they are moulded into the body (last owner did that...) But I could attach a small rubber bit onto the underside of the arch that just goes far enough to be legal. Making sure it looks good tho, no dodgy crap for me, not anymore at least!
PostPosted: Wed Nov 01, 2006 8:20 pm
Slow-Po
Come on, you can't make a post like that without pictures?! :)
PostPosted: Wed Nov 01, 2006 8:26 pm
slinkey inc wrote:
Not much but from looking from directly behind you can see the widest part of the tyre out, the top is just in. !
it no tread is showing outside the widest part of the flare, it should be OK
PostPosted: Wed Nov 01, 2006 8:45 pm
could you fix this with rubber stripping from clark rubber, i think it only says it need to be cover and have a non pernatrating edge,
PostPosted: Wed Nov 01, 2006 9:11 pm
I'll take pics 2moro I tryed but even the flash ain't tough enough
PostPosted: Wed Nov 01, 2006 9:23 pm
I refuse to reply to this one until I see pics.......... I love pics
If it cant be fixed with a hammer it cant be FIXED!!
PostPosted: Wed Nov 01, 2006 9:29 pm
Here you go, I went out into the cold darkness for this...tyres are covered in dust i went for a hoon and our driveway (gravel) makes massive amounts of dust, hard to keep mins clean (immposible)
PostPosted: Wed Nov 01, 2006 9:34 pm
there beautifull. lol... they seem ok to me, hard to tell from that shot though need one from the back or from the front... So im affraid your going to have to go back out into the cold again slinky....
Now hurry back
PostPosted: Wed Nov 01, 2006 9:38 pm
Whats with the flares...
You bought them from Moneysport yeah?
PostPosted: Wed Nov 01, 2006 9:46 pm
Bought mags and tyres from 'moneysport' and yes they were dam expensive! But flares I don't know, came on car, and I kind of like the moulded look so I kept them. I had an other look, i figured my solution, just a half inch of black rubber extending from it, i saw a pic in a miniworld of a mini like that, it looked alright.
Nah, I'll clean the car up and take pics at mini at the mill, not you that anyone will want to see thme but I do....hehe.... Have to re-lower the car as the passenger side wheel was rubbing so I raised the car a bit then a lot, and didn't work then. So I lowered down a bit, took the wheel off, hit the inside with a copper mallet a few times and now it fixed!! LOL!
PostPosted: Wed Nov 01, 2006 10:11 pm
you've just copied willy
PostPosted: Wed Nov 01, 2006 10:33 pm
Whoa...what's he got? If it's the same I reckon he wouldda copied someone else. He wouldn't be the first to have minator's and formula R's and he sure don't have my archs. He's got a rover, most likely with rover archs??. Anyways mine's better as...well I don't know, Oh yeah my car is red. 8) :lol:
 Post subject: Moneysport
PostPosted: Wed Nov 01, 2006 10:43 pm
'Moneysport "...I must say i like it :wink:
Maybe we could change our name..... :D
Andrew@Minisport, South Australia
Ph: 08-8177-1275
Skype: minisport.au
www.minisport.com.au
Minisport for all your mini parts
 Post subject: 6 x 10s and flares
PostPosted: Thu Nov 02, 2006 1:26 pm
Hi,
I've got a similiar setup, 6 x 10s (miniators) and, suprise suprise, dunlop formula R's :)
Yep, the tyres stick out. What can you do? Unless you are lacking in the negative camber department, all you can do is add some sort of material to cover the tyre, whether it be solid rubber, aluminium or plastic/fibreglass. It can't be sharp (test: run finger along it quickly).
Me: I've order group 5, 3.5 inch wide rims from the UK. Not interested in mucking around with a solution (can make custom aluminium templates etc.) Incidently they cost me AU$78 for the flares and $142 for the shipping!! Still cheap, just a bitch to mail.
Question - you are not running spacered drums on the back? This would be the reason they don't stick out at the rear. Mine do :)
Good luck.
 Post subject: Re: 6 x 10s and flares
PostPosted: Thu Nov 02, 2006 1:37 pm
Buy 10x5 like I did :wink:
Users browsing this forum: Bing [Bot] and 104 guests
