It is currently Wed Aug 13, 2025 4:19 pm
 Post subject: Point to ponder
PostPosted: Tue Nov 07, 2006 8:25 am
Question: In the ideal engine , does the water jacket completely surround the cylinder bores?
While cleaning out the solid crud in the motor at the weekend I noticed that some of the wires that were use to hold the sand cores together during casting were still poking out from between 1&2 and 3&4 and as a result solid rusty material closing the gap between these cylinders. Obviously this would inhibit water flow in these areas and not cool as effectively.
Point to Ponder: Could some of the "hotter" running engines out there be a result of poor removal of manufacturing artifacts and is there anything that can be done about it?
David L
PostPosted: Tue Nov 07, 2006 8:31 am
always get the block & head hot tanked, it'll clean out that rusty crud.
PostPosted: Tue Nov 07, 2006 9:21 am
Yes you are right! if it looks bad in there then it probably is!
My block looked great inside, until I washed it about half a dozen times and it started to go orange :oops:
 Post subject: Re: Point to ponder
PostPosted: Tue Nov 07, 2006 5:08 pm
In the ideal engine it does. In the A series it doesn't. 8)
PostPosted: Tue Nov 07, 2006 6:31 pm
Smallbore blocks are cast in 2 siamese pairs, 1-2 and 3-4. water only between 2 and 3.
The bigbores have NO water between the bores- it's one lump of iron....!
Wombat, the bits of wire are called chaplets, they were to support the sand cores during casting.
Often when overboring a block you hit one, no big deal. :wink:
Users browsing this forum: No registered users and 280 guests
