I think this will help you!!!
I still have a hole in a Door after this
Gasket Goo.....Just a quick little Story...When we purchased Sue's Daily Drive we did the normal test to see if it was blowing smoke and thew Box and all...two weeks into it it was blowing smoke..two days later it was the Bat Mobile
What had happen the PO had used GG on the Head gasket but had put tomuch on and it endend up blocking number one water jernals and cooked it
Go with the ACL gasket, as mention its easy to reconize
with the Studs and get the Head surface cleaned up to ensure its flat.
One thing that has not been mentioned...Please get a air-compressor and blow out the holes where the studs are...just incase thier is oil or water in thier
