It is currently Wed Aug 06, 2025 7:50 am
PostPosted: Sat Nov 18, 2006 5:34 pm
the master cylinder return spring is broke :roll:
never seen nor heard of that before. the rubber bits are fine, and apart from a bit of rusty goop on the outside end of the piston, there is not much else wrong with it. must have been a bit short of stroke to activate the clutch.
so is it possible to get new springs? got to be heaps better than a whole new cylinder...
or does anyone have a spring they don't want? guess i'll have to put that in the wanted section and cross link etc... http://www.ausmini.com/forums/viewtopic.php?t=25038&highlight=
michael
PostPosted: Sat Nov 18, 2006 5:51 pm
you mean slave cylinder return spring?
it's wierd that'd be the cause, but I guess anything is possible with a mini. I forgot to put one on my van once and the clutch still worked normally - until the thrust bearing turned itself inside out
one of the sydney bods will have a little collection of old springs like I have, or if it's just broken at the end where it goes over the hooks at the end, how about opening up the first coil of the spring?
 Post subject: Sproing
PostPosted: Sat Nov 18, 2006 6:14 pm
AFAIK you can run without the return spring...all it does is add to the heaviness of the pedal :?:
PostPosted: Sat Nov 18, 2006 6:24 pm
I was always led to believe the return spring was to hold the arm back so the clutch bearing wasn't on the diaphram .
 Post subject: springs
PostPosted: Sat Nov 18, 2006 6:27 pm
hi apparently they are so there is no slack between full out and full in or so I have been told.
Hellooo from OODLES my mini. Is being restored to be revealed in all her glory one day in the future she looks forward to meeting you all.
PostPosted: Sat Nov 18, 2006 7:33 pm
Guys he said the MASTER cylinder return spring is broke
Won't work without that one.... :lol:
A brake shop would be my bet. :wink:
PostPosted: Sat Nov 18, 2006 8:04 pm
nope
like Kev says - i mean the spring inside the bore of the master cylinder that ensures the piston moves all the way back to the bottom of the bore. here are the pics of what i pulled apart and cleaned up this afternoon. (gotta love the dremel :D )
the spring was actually snapped as it came out, and on the larger section there is another piece about to come off. it is a bit odd, because it does not look much like a fatigue failure, more like ductile. but i suspect that the surface of the spring may be hardened and if you crack through the surface, its all over :cry:
i'll have to ring around on Monday i suppose.
michael
PostPosted: Sat Nov 18, 2006 9:30 pm
i'll have one somehwere, come and see me at some point and i'll dig one out
Aaron
PostPosted: Sun Nov 19, 2006 1:28 pm
thanks - but i got two from Chong with the exhaust (the 40hp one? :lol: ) today. will have it all together and operating this afternoon - hopefully.
michael
PostPosted: Mon Nov 20, 2006 3:09 pm
I had the same thing happen on my Corolla ('86), the spring was broken into about 5 pieces :shock: I had to get a second hand cylinder from the wreckers because I couldn't find a spring anywhere. It turned out that the broken spring was made from slightly thinner wire than the spring in the replacement cylinder. :?
Before you judge someone, you should walk a mile in their shoes. That way, when you judge them, you are a mile away and you have their shoes.
Users browsing this forum: No registered users and 72 guests
