It is currently Mon Jul 21, 2025 7:48 am
Post new topic Reply to topic  [ 70 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Fri Nov 24, 2006 3:08 pm
are your leads on correctly?
PostPosted: Fri Nov 24, 2006 3:10 pm
Die Die Die!!
id assume so... it has turned over..
PostPosted: Fri Nov 24, 2006 3:15 pm
yeah, it will turn over if your leads are on wrong
PostPosted: Fri Nov 24, 2006 3:22 pm
Die Die Die!!
then i guess its a possibility... anyone got some sort of guide.. i mean telling me its 3-2-1-4 or watever it is doesnt help as i dont know where it numbers from..
PostPosted: Fri Nov 24, 2006 3:25 pm
Just go back to my earlier post telling you how to find Top Dead Center of number 1 , then looking at the dizzy from the front of the mini go anti-clockwise 1 , 3 , 4 , 2 .
PostPosted: Fri Nov 24, 2006 3:27 pm
Die Die Die!!
alrighty.. ill check it out 2moro.. :)
PostPosted: Fri Nov 24, 2006 3:38 pm
Die Die Die!!
just tried it just before i take off to a mates... and the plugs where in total reverse order :S .. hopefully ill have it going 2moro.. thank heaps for the help so far evryone :)
PostPosted: Fri Nov 24, 2006 4:18 pm
Hmmm , someone please confirm to me that it is anti-clockwise when looking at the dizzy from the front ????
PostPosted: Fri Nov 24, 2006 4:25 pm
confirm
PostPosted: Fri Nov 24, 2006 4:30 pm
Phew , I wrote the previous and then when 666 said they were wrong I had to stop and think , but not worried enough to go downstairs and check ....
PostPosted: Sat Nov 25, 2006 1:08 am
Die Die Die!!
i assume your number 1-4 on the engine left to right ?
PostPosted: Sat Nov 25, 2006 6:12 am
No , number 1 is the water pump end , number 4 is the clutch end .
PostPosted: Sat Nov 25, 2006 7:50 am
Die Die Die!!
oh.. then they were in the right way...
PostPosted: Sat Nov 25, 2006 7:54 am
D'oh ...
PostPosted: Sat Nov 25, 2006 10:13 am
Die Die Die!!
tried starting it.. heard some loud pops... then still wouldnt turn over.. then i remembered to turn the plugs round the right way.. and still nothing... its like its not getting fuel.. but it is....
eidT: oh and now the battery is flat... i have to go and buy a battery charger
