It is currently Fri Jul 18, 2025 7:16 pm
PostPosted: Thu Nov 11, 2004 8:00 pm
Location: thornleigh sydney...round crnr from suzitech!!!!
hey all again...
i want to make custom door trims for the van,
ive already bought the ply wood n fabric, but i want to remove the door pockets.
is there anything i should know before i take to them with a hack saw???
cheers once again!
blake :shock: :wink: 8)
ausmini member 195
71K 'Kaye', KAZZ69's work in progress
66 panelvan, going no where fast...
71 MS75 toyota crown COUPE :) yes A COUPE!
76 ra23 celica wid 1ggte, GT3071r, 13.5@106mph with alot of spinin....
wheels keep on turnin!
PostPosted: Thu Nov 11, 2004 8:05 pm
The first thing you should do is swap doors with me!
I have a pair of clubbie doors with the pockets removed and I want doors with pockets.
 Post subject: pocket removal
PostPosted: Fri Nov 12, 2004 9:20 am
Try using a drill to drill through the spotwelds half way and then using a chisel (for metal) to hammer it off. On my van I used this method and I had a clean result
PostPosted: Fri Nov 12, 2004 9:56 am
how much u want for the doors ?
lookin for another clubby
PostPosted: Fri Nov 12, 2004 10:55 am
Yeh, easy peasy, just drill the spotwelds away and you good to seperate the metal. I've done it to one of my doors, but I think i'm gonna try and get different doors, mine has already been welded up once before (front corner where the window trim thingy start to go over the wind and back down) and its broke again.
 Post subject: .
PostPosted: Fri Nov 12, 2004 5:30 pm
cheers all
i just thought there would be significant structural weakness if i were to remove them!
(hey im as stupid as i look!) :wink:
hehehe
cheers,
blake :D :D :D
ausmini member 195
 Post subject: .
PostPosted: Sat Nov 13, 2004 7:19 pm
hey,
i made my door trims will put pictures up when i fix the rust behind the drivers door hinge's!
:cry: :cry: :cry:
they look awsum!
im also in the middle of making custom door speaker pods,
i had some trouble locating the spot welds????? :( :(
and the metal chisel just riped a hole in the door....not noticale though!,
so the next best thing was to have some fun with a 100mm angle grinder, got it off nice and quickly with a clean finish!
cheers lads,
blake
ausmini member 195
