adeee wrote:
poeee edit/ you can get to ausmini by going straight to the ausmini IP address 61.14.187.197. To get to the forums go to
http://61.14.187.197/~ausmini/forums/ however, you may or may not have problems with the forums (if you get a link sending you to
www.ausmini.com/forums/xxx then you may have problems).
Thanks for the IP info poeee.
Info for all you Bigpond users:- there's a file in your C:\Windows\System32\Drivers\Etc folder called HOSTS. Edit this file with notepad (or get someone to do it for ya if not sure) and add the line
61.14.187.197 ausmini.com
to the bottom of the file. Ensure there's at least one space between the 7 and the a.
Your machine will consult this file for the ausmini address.
Here's what the file looks like after editing:
# Copyright (c) 1993-1999 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
127.0.0.1 localhost
