It is currently Sun Jul 20, 2025 8:37 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Thu Dec 14, 2006 8:15 am
Just measured mine - both 0.75" - OK I'm running a servo 8) but that means I've bought the wrong kit :evil:
David L
PostPosted: Thu Dec 14, 2006 9:22 am
Clutch M/C should be 0.75" bore, a .70" (brake one) doesn't move enough fluid, causing clutch drag and dodgy adjustability.
I know this as I've bought several cars that had em on.... :evil:
Your brake M/C should be 0.70" bore for most everything with twin leading shoe drums, or discs.
If you use a 0.75" pedal effort will be too high- unless running a servo.
Even the Cooper S ran a 0.70".
So, I wouldn't swap `em, for these 2 reasons. :wink:
With the plastic extensions it makes no difference, it's easy to top up.
I'm sure you can turn the correct brake MC around when mounting it - ie still mount it on the brake MC location but just with the top up cap away from the firewall - I've done this on my car.
BUT it seems that in the 2nd pic (the white car) the MC's werent just turned around but were actualy swapped in places. They just look like the wrong MCs for their spots - (ie the brake MC is in the clutch MC's spot and vise versa). Am I wrong here?
PostPosted: Thu Dec 14, 2006 1:59 pm
If you turn them around they have to swap places as the flange is on a different angle and you can't get them on as they are too close to each other. So although both mine are 0.75" they are brake and clutch as the flanges are different.
Oh and I've decided to put the filler to the back as original :roll:
David L
PostPosted: Thu Dec 14, 2006 4:43 pm
850s originally had both cylinders 0.75" bore.... :wink:
Are you still running the old 850 single leading shoe front brakes? I'd swap them with Deluxe ones (or discs!!) if so.
PostPosted: Thu Dec 14, 2006 4:46 pm
No got twin leading shoe; PO must have swapped them when he put the 1100 in
David L
PostPosted: Thu Dec 14, 2006 5:00 pm
Your .75" MC will be OK with a servo, but if no servo I'd get a 0.70" one.
Too bloody hard to push otherwise. 15% harder... :wink:
PostPosted: Thu Dec 14, 2006 9:04 pm
my 850 has .75" m/c and servo with deluxe drums. it pulls up nicely, little effort on the pedal, but its a LOOOOOOOONG pedal :wink: standard outcome of adding a booster :lol: so that can work in my limited experience.
incidentaly the booster is mounted in the boot, and there is a vacuum tank under the rear seat to maintain brakes in case of engine failure (all according the the prvious owner who had it 40 years and put these in 8) )
my other car also has cooper S discs WITHOUT a booster. total opposite in feel.
michael
PostPosted: Fri Dec 15, 2006 11:42 am
I'm pretty sure you can turn atleast the brake one around without swapping them places - I'll get a pic of mine as soon as I'm finaly back to Sydney
Users browsing this forum: Majestic-12 [Bot], Scoop and 70 guests
