It is currently Sun Aug 10, 2025 9:56 am
PostPosted: Mon Jan 08, 2007 10:46 am
I would add....tape or hold some sort of flat sheet over the radiator fins to protect against accidental damage when removing.....too easy to to damage if you slip or whatever.
PostPosted: Mon Jan 08, 2007 10:59 am
Personally I would leave the radiator in especially if you have the engine lifting bracket, a hydraulic crane and the car up on jack stands with the pot joints dropped.
I have always found that struggling to undo radiator shroud bolts and getting the bottom radiator hose off and then getting the radiator past everything does more damage than lifting the engine straight up til everythings clear (with the earth strap and the speedo cable undone) and then move back with the power plant and ancillaries. Lower it and place it on a trolley or blocks of wood.
Then you have all the time and room to undo and remove the radiator without working in a tight space.
PostPosted: Mon Jan 08, 2007 3:53 pm
Location: hoxton park,sydney a place where our council bins are so small you couldn't bath a baby in them!!
depending on what you plan to do to the engine
if you are only giving it a little cleanup / cosmetic rebuild then all you really need to do is
disconnect the gear change stuff ,speedo cable ,engine steadies, fuel system ,brake pipe for the front ,all the wiring
then undo all the subframe bolts after supporting the subframe on some wood/milk crates/anything solid...etc
then get a mate or two to help you lift the front of the car over the engine
you won't have to worry about lining up mount holes (contorsionist style) , rebuilding cv joints (tends to be messy) you'll get a good chance to chean up more of the body where the subframe was
the subframe it self can be tendered to as well
and if you really want to get the engine off that it's only another 4 nuts and bolts an earthing strap and 2 cv joints
best bit is you'll same some money on engine crane hire and it'll give you a good excuse to spend the money you saved on beer
just remember to remove the lead bricks out of the front.....
why does everyone want a Cooper S when you ca have a better Clubby
PostPosted: Mon Jan 08, 2007 5:34 pm
A bit of cardboard box taped over the radiator would help protect it from damage.
When I used to pull out my 1275LS engine, I used to remove everything off the engine, then I would jack the motor up with the floor jack and lift it by hand onto a milk crate (by myself) I used to be strong and stupid. 8)
I have an engine crane these days. :wink:
PostPosted: Mon Jan 08, 2007 6:04 pm
I don't want to get too far off topic - but a friend of mine was a Navy band member in the Vietnam War days and sailed 3 times to Vietnam on the (?)aircraft carrier used as a troop ship. He had a Mini that needed work so he rented a garage from a little old lady over the road from the docks. He got 4 mates together and they lifted the motor out and carried it - one on each corner - up the gangplank and into the hanger area where he worked on it to his hearts content in his free time - which for a band member was plenty :wink:
David L
PostPosted: Mon Jan 08, 2007 6:15 pm
The modified troop carrying aircraft carrier was the HMAS Sydney and also known as the Vung Tau ferry.
Yeah I quite belive that story could have happened - that and other similar stories makes modern service people cry with despair as in some regards the modern services bear little resemblance to the forces of the sixties.
On the other side todays services are extremely professional and are virtually hand picked for certain jobs. Back then it was just a numbers game - get enough servicemen and you will find someone to do the job - regardless of their willingness.
 Post subject: Keh??
PostPosted: Mon Jan 08, 2007 7:04 pm
I used to be strong and stupid. 8) :wink:
Was that last week Mike :P :?:
 Post subject: mission complete
PostPosted: Sat Jan 27, 2007 11:50 am
completed the engine removal today with the help of kevin thanks mate
everything ran pretty smooth besides one of the tie rods was stuck we couldnt seperate it but we worked around it and got the pot joints out so it was ok
took around 2 hours
didnt remove the radiator or antyhing we used doogies method and it seems to be relativly easy
thanks for the help
cheers bob
1978 NUGGET GOLD 1275 LS
PostPosted: Sat Jan 27, 2007 12:35 pm
good to hear mate !!
Users browsing this forum: Bing [Bot], Hawken and 103 guests
