It is currently Sun Jul 20, 2025 1:15 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2, 3  Next
 Post subject: manifold database
PostPosted: Sat Jan 13, 2007 8:01 am
Since there are so often people asking about different manifolds (weber and SU) I thought we might start a database with pictures of various manifolds . I have a couple of weber manifolds (gooseneck and mid length) and various twin SU manifolds that I'll take pics of later and post , who else can provide pics ? Ideally pics of the manifold by itself or with carb but especially side on in the case of the weber manifolds for easier reference . Pic's of them in the car can be a little difficult to figure out at times ...
PostPosted: Sat Jan 13, 2007 8:10 am
metro turbo manifold (flanges have been milled to 8mm on this one , they are usually 12mm and water conections were cut off). To suit a hif44 turbo carburetor but any hs4 or hs6 or hif38 will fit. There are a water cooler manifold as std , probly not very good for n/a for but work great with boosted aplications.
the second picture show the complete metro turbo carburetor setup althought blow off valve non std and plenium has been modifyed for intercooler.
PostPosted: Sat Jan 13, 2007 8:16 am
I've got pics of Russell Engineering Weber one-
Redline 3005, after some porting-
PostPosted: Sat Jan 13, 2007 9:11 am
D.P.E Manifold to Suit a HIF44 Presently on a modified 1100
Don't know much about it realy...but much better than the Log I had before
PostPosted: Sat Jan 13, 2007 10:32 am
This is a stocker that i used to use. To suit twin 1 1/4in SU's. Originally i think its off a Sprite. Note there is no Vac take off on this manifold.
This is an aftermarket one that i bought from somewhere...?
PostPosted: Sat Jan 13, 2007 1:40 pm
These are factory cast manifolds.
The first one is a 1.5" SU standard cast manifold but has had the exhaust part removed with an angle grinder to allow fitment of extractors.
The second one is an MG Metro factory cast manifold to suit a 1.75" SU carb. The exhaust pipes can be cut off to allow fitment of extractors, although the factory ones do flow fairly well, and you can have LCB style pipes made to fit. A 1.5" SU carb can be used on this manifold too.
For split webers, you may want these.... 'R. Longman & Co.' cast alloy manifolds. They are 2 seperate pieces. FIrewall needs a large box section fabricated to allow fitment of the complete assembly.
PostPosted: Sat Jan 13, 2007 1:55 pm
This is my 5th attempt , the forums don't like too many carb sizes etc in a post as it stuffs the system and refuses to post .....
<EDIT> No , it wasn't saying the various carb sizes , it was whenever I typed the name of the company who made the gooseneck weber manifold and the twin 1 1/2 manifold at the bottom of the post in the post it would come up with error messages and refuse to post ..... Frustration plus .
Gooseneck for weber
Warnerford 4 inch for weber
BMC twin 1 1/4
Hi Torque twin 1 1/4
Unknown twin 1 1/4 , only casting marks are the firing order
Unbranded twin 1 1/4 on the sports850
Tiny twin 1 1/8 Alexander
Twin 1 1/2 made to fit two standard carbs , not a left and right pair .
PostPosted: Sat Jan 13, 2007 4:16 pm
Note that Warneford `4 inch' one is identical to a Redline 3005- Redline bought the patterns or the company, not sure which.
PostPosted: Sat Jan 13, 2007 4:21 pm
I thought it was the one that was the same , I'll get it off and take the weber off for a better photo when I get the chance .
PostPosted: Sat Jan 13, 2007 5:20 pm
Twin SU manifold by Lynx, shown here set up for twin HS2s, but can also take twin HS4s or HS6s if you change the studs & enlarge the ports.
PostPosted: Sat Jan 13, 2007 5:24 pm
Oh and I also had mega trouble with it refusing to post, so it's something to do with L ynx then??!
PostPosted: Sat Jan 13, 2007 5:28 pm
Yes , same drama's as I had , I can't use that word with a capital L for some reason , the forum thinks I'm giving it an instruction to do something that it's not allowed to do ....
PostPosted: Sat Jan 13, 2007 5:33 pm
whinja ninja
whinja ninja
i've had no problem posting the word Lynx
I don't know my name anymore.
PostPosted: Sat Jan 13, 2007 5:39 pm
I had problems this morning, more than 3 lines of text and it denied me access. :evil: :!:
PostPosted: Sat Jan 13, 2007 6:29 pm
Yep me too..... I was updating an old post which already had the word in it (all in capitals) and it kept giving me a 404 error. I removed the L word and it updated the post without a problem.
/end of thread hijack
