1018cc wrote:
According to my list that engine number corresponds to a "Mini Clubman Saloon" - sorry but that's as best as my list does.
The engine number prefix on the early Leyland Minis is a bit of a nightmare, they gave an code to each different car and then any changes to engine spec give it a new number.
This list may not be accurate but it is a start, it is the result of a number of books.
1000 = Mini 1100 (Clubman base model) / Mini Van. High comp, direct gearchange.
1001 = Mini Clubman. High comp, remote gearchange.
1002 = ? (Possibly replacement engines) (has no gearbox) High comp.
1003 = Mini 1100 / Mini Van. low comp, direct gearchange.
1004 = Mini Clubman. low comp, remote gearchange.
1005 = ? (Possibly replacement engines) (has no gearbox) Low comp.
1006 = Moke.
1007 = Mini Clubman (may now be called a Mini S) / Mini Van.
1008 = Moke.
1015 = Mini S/ Mini Sedan (Leyland decided to cut down on the number of prefixes so all Minis and Mokes got the new code)
1200 = Clubman GT. Twin carb, Close ratio, remote change, high comp, electric fuel pump.
1201 = ? (Possibly replacement engines) High comp, no gearbox.
1202 = ? (Possibly replacement engines) High comp, no gearbox.
1203 = ? Single carb, standard ratio, direct gearchange, high compression, pollution gear.
1204 = Moke (probably the first Californian)
