It is currently Wed Jul 30, 2025 12:18 pm
PostPosted: Wed Jan 17, 2007 12:48 pm
Ok, I've read lots into all the brake conversions, but what about using stock 8.4 discs and 4pot calipers (KAD or something) or even standard calipers. Would the same still apply, a special braket and spacers??
Your thoughts?
PostPosted: Wed Jan 17, 2007 12:58 pm
The KAD calipers would bolt straight onto Mini disc hubs, as far as I know.
PostPosted: Wed Jan 17, 2007 4:45 pm
I realise that, thats why I want to know if its possible with a simple adapter plate (ie. to use drum uprights) as in the other conversions.
The whole point is to avoid the $350+ cost of each disc upright, and instead use common mini parts including the drum uprights I already have.
PostPosted: Wed Jan 17, 2007 5:23 pm
I would recommend using disc hubs.
PostPosted: Wed Jan 17, 2007 5:29 pm
wait till minispares uk has them on special, i got my hubs for $330NZ inc postage, NEW. 8)
PostPosted: Wed Jan 17, 2007 5:53 pm
A spacer on a drum hub would have to be so thin to fit between the hub and disc that it wouldn't hold up the caliper! :D
PostPosted: Wed Jan 17, 2007 6:09 pm
What he said.... ^^^
And don't even think about welding a lug onto the drum upright. Apart from being illegal, the swivel hubs are a grade of cast iron, which does NOT like bits being welded on.
How do I know this?
I have machined swivel hubs inside to fix `em when worn, as a machinist I know what cast iron turns like. :wink:
PostPosted: Wed Jan 17, 2007 10:08 pm
Thanks guys, I knew not to weld cast iron (although I did weld a small hole, breather??, in a 1-1/2 SU manifold).
So how do these other conversions work then? Is there more offset on the disc to allow a bigger spacer to fit between hub and caliper?
PostPosted: Wed Jan 17, 2007 10:15 pm
shallow-er disc rotor (hat)
PostPosted: Wed Jan 17, 2007 10:18 pm
What he said...^^
They are shallower because they use single piston sliding calipers, which stick outwards less. :wink:
So, there is room for a mounting bracket to bolt onto the outer face of the swivel hub. For a Honda setup they are about 7mm thick.
