It is currently Wed Aug 06, 2025 11:45 am
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Sun Feb 11, 2007 6:39 pm
I actually have the sam problem on the drivers side wheel. The tyre rubs on the corner of the guard. I run a dry setup with 12inch rims, i have a feeling it has all got to do with the geometry of the wheels ie tie bars and adjustable bottom arms.
Dan
PostPosted: Sun Feb 11, 2007 6:45 pm
Give Ash some flowers Nick .
I run 10" wheels on hydro with 165/70R10's and with flares and never have any problems - I'd say its a deeper issue than the tyre profile.
PostPosted: Sun Feb 11, 2007 9:42 pm
I is a mookenik
well mines not drum and the front its had a disk conversion done and the rims are wider so yes thats why it had 16570r10's on it i might check the alignment adjustments
PostPosted: Mon Feb 12, 2007 12:42 pm
You said in a post that your car was hydro.... and then in another post you said it WAS hydro but had been fitted with springs and shocks when the hydro crap itself.
SO are you saying that the suspension is now rubber cone type fitted to hydro subframes?? Maybe the front trumpets have been shortened, or are possibly hi-lo types set too low??
The greater offset wont help the situation, jacking the front up a bit should cure it without hacking the body.
PostPosted: Mon Feb 12, 2007 6:04 pm
I is a mookenik
thats its LOL.. its got hi-lo suspension installed in it but it looks like the hydro is still there but, like i said i only has juz bought the car so im learning what the car has and hasnt got and another point im new to mini's im juz telling u what i see in front of me, but at work we check that the driver side is lower then the passenger side and that the driver side wheel looks more forward then the passenger could this be a problem?
PostPosted: Mon Feb 12, 2007 6:09 pm
OK , now it's making sense , does there look to be any accident damage at the front anywhere (could anything be bent in the suspension?) or is it likely to be suspension oriented do you think ? As for one side being lower , take the wheel off and wind it up a little , the front works on a 1 in 4 or so ratio , if you wind it up 1mm it will lift the mini 4mm (keep forgetting the ratio but it's somewhere there , just don't wind it up 20mm expecting it to lift 20mm , you'll end up 80mm or more higher ....) or so .
PostPosted: Mon Feb 12, 2007 7:05 pm
I is a mookenik
ah ok nh theres not accident damage its gotta be a wheel alignment or suspension problem for sure, how hard is it to wind it up
PostPosted: Tue Feb 13, 2007 10:35 am
Front ratio is 1:3, rear is 1:5.
The hi-lo should be an alloy trumpet with a thing that looks like a large bolt threaded into it, locked into place with a large nut against the alloy trumpet. Winding the bolt out of the alloy trumpet will raise the car.
When you wind it out, measure the length from the threaded face of the alloy trumpet to the top of the bolt...... and make the one on the other side the same distance. Assuming all your suspension parts are in good condition, it should make your car level.
