It is currently Sun Jul 20, 2025 1:33 am
PostPosted: Tue Feb 06, 2007 2:48 pm
ok so i've been ahvig a pretty good run with armageddon lately, he's been behaing himself. up until recently. he has started to lose coolant at an alarming rate (eg about half a litre a day) and is overheating as a result. i had the plugs out today, they had a decent amount of carbon foulin on them but there were no signs of water in there, i woulnd the engine on a bit to see if there was any in there but no, none.
yet to ahve a look at the water pump though, gotta get on that.
so this morning i cleaned up the plugs, topped up oil and coolant (took about 500-1000ml of oil, and filled coolant with motor running), and the temp is not evne reaching the N on the gauge?????
interesting :?
PS no mayo in oil filler cap
78 Leyland Mini - Prince
PostPosted: Tue Feb 06, 2007 3:38 pm
Maybe your Armageddon is just thristy :idea:
My new green mini Turtle JAC is also a coolant muncher.
3L in two days ... :o
i just buy him more coolant.
our cars can be friends. christmas colours! :lol:
PostPosted: Tue Feb 06, 2007 3:39 pm
Don't talk to me about overheating! :roll:
PostPosted: Tue Feb 06, 2007 3:44 pm
You getting hot under the collar Scott because Adeee is making you clean your room/s????? :shock: .. :D
PostPosted: Wed Feb 14, 2007 11:36 am
UPDATE:
since spending about a day under the N, i'm regularly having overheating problems. where could the coolant be going???
also i've just re-read my post above...i sounded really drunk! im just bad with typo's i think i've caught something off makka hahahahaha
PostPosted: Wed Feb 14, 2007 11:40 am
Maybe theres a hole in ur coolant system dear lizza dear lizza?
Go to a radiator joint and get a pressure test done, will take 30 secs to identify if there is a leak, should cost you free dollars.
PostPosted: Wed Feb 14, 2007 12:00 pm
I used to have this same problem..... I ended up flushing it everything I could think off. The problem wasn't anything remotely major, it was a hairline crack in the bottom rad hose barely visible until I shown a bright light down it and block off the other end.
best of luck fixing the problem
PostPosted: Tue Feb 20, 2007 1:26 pm
yeah gotta get a pressure test done, i think natrad are doing them free atm. im thinking it could be a cracked hose, the rad is less that a year old so i'm fairly sure its fine.
noticed hissing noise coming from rad cap, so changed it (but not same pressure, i think this new old one has a greater pressure)
so pressure test here we come! with a lot o luck its not the head or gasket i'v had enough of that. gotta get the block properly done
PostPosted: Tue Feb 20, 2007 1:29 pm
check cooling system (flush/look for air)
check mixture (a lean engine is a hot engine)
PostPosted: Tue Feb 20, 2007 2:04 pm
hmmmm i am running lean... i also think my choke is stuck out a bit though. how to fix?
PostPosted: Tue Feb 20, 2007 2:07 pm
push it back in from under the engine bay...
PostPosted: Tue Feb 20, 2007 2:30 pm
cheers :D
PostPosted: Tue Feb 20, 2007 2:53 pm
Did you replace the rad cap?
Mine started to lose an amazing amount of coolant (water :roll: ) and get hot. I got all worried, thinking the worst.
Turned out the rad cap had corroded and it wasn't holding the spring down enough, so no pressure. $12 and it was fixed :D
PostPosted: Wed Feb 21, 2007 9:11 am
hey zoidberg.
i did hange the rad cap but it was with an old one which i think i took off my car a couple of years ago. if i buy a new one, what pressure do i need? (also the one with the long spring...)
PostPosted: Wed Feb 21, 2007 10:22 am
13psi :wink:
Users browsing this forum: No registered users and 69 guests
