It is currently Wed Jul 23, 2025 12:22 pm
PostPosted: Wed Feb 14, 2007 4:14 pm
I would just pump it up... if it blows any bags someone offered you some, I have a bunch of 12 also. :wink:
 Post subject: Wet
PostPosted: Wed Feb 14, 2007 4:16 pm
Listen to the Doctor, 320/330 isn't going to blow the bags if they are taking 300 already. You need to look carefully at what has been said above and check each item one at a time.
Otherwise, go to a Mini expert to get it sussed out :idea:
PostPosted: Wed Feb 14, 2007 4:23 pm
they are getting pumped up tomoro morning by a mini specialist so ill try around 320-330 and see how it goes, lets jus hope the bags keep up with the pressure.
1992 Toyota Starlet GT EP82
PostPosted: Thu Feb 15, 2007 11:43 am
got the hydro pumped up today and looks alot better than it did, raised the car bout and inch. Pumped it up to around 320-330, was on around 280 before being pumped, the specialist advised me (as did others on here) if i wanted to go any higher to put the packing spacers in..... driving home was alot smoother, i was truly "floating on fluid" alot better than ridin on bumpstops :lol: i cant se any leaks anywhere so i will have to keep an eye out and see how it goes. so heres a few pics
this is the new ride height
no longer sitting on the bumpstops!!! :D
oh! and mr. mini ticked over 80000 miles on the way there!
cheers all for the help, ill be sure to keep in touch with you mokesta
>Rude<
 Post subject: Petal
PostPosted: Thu Feb 15, 2007 6:01 pm
Well done :D Keep in mind the car will settle a little lower after a couple of weeks driving....don't sweat it..just enjoy driving it :D
PostPosted: Thu Feb 15, 2007 7:43 pm
Give Ash some flowers Nick .
You'll be fine - my car is still hydro and I just get it pumped up to what ever height I find desirable. If one of the bags blows again (it had one bag blow about 30 years ago) there are heaps of people that have them stored away. Don't start thinking that there aren't many around.
Glad to hear eveything is going smoothly (pun intended)!
