It is currently Sun Jul 13, 2025 9:34 pm
 Post subject: PG
PostPosted: Sat Feb 17, 2007 10:58 am
Baracade wrote:
Yeah i heard the one that has been made in Australia was made in QLD.. but is running around in sydney somewhere..
But have not really tried chasing it up really..
Paul Gulson's car is believed to be in Victoria.
PostPosted: Sat Feb 17, 2007 8:17 pm
A year ago when we visited this subject wasn't there someone on the Gold Coast putting single rotor off a 13B into Minis?
Rotormax, or someone... :?
PostPosted: Sat Feb 17, 2007 9:21 pm
13secmini
Well i have found out that the guy that does the rotory into mini conversions is still around. His name is doug and hes number is 0438 759 674.
He uses a 13b single rotor mated to a mitsubishi cordia gearbox. I have been given this info from a friend of his off the ausrotory forums. He states the reason why single rotors are used is cause you get ample reliability and power and revs... who needs torque when you have 15.000 revs to play with..
and also, cause the standard endplates are used, then you have a water pump and oil pump that are meant for two rotors, so ample cooling and lubrication aswell, reliability comes form the fact that a shorter "crankshaft" is used, so less flex and more revs!!
So if anyone is seriously looking at doing a rotor conversion then give give him a call and he will be more than happy to answer all questions about all aspects...
and get as much info as possible.
edit:
more of that nz mini
Car Details
CLASS: GT3
CAR MAKE & MODEL: Leyland Mini
WEIGHT: 740kgs
CLUTCH: Twin Plate
TRANSMISSION: Toyota Corona 5 Speed
SUSPENSION: MacPherson Struts
BRAKES: Four Pot Front / 2 Pot Rear
TYRES: Dunlop 200/580x15
ENGINE: Mazda Rotary 12A Turbo
CAPACITY: 1146cc Turbo
MAX. POWER: 250HP
MAX. TORQUE:
FUEL: Avgas
OIL: Valvoline
ENGINE BUILDER: Tony King
Guys I have a magazine feature on this car. It is powered by a 12a turbo rotary mated to a toyota corona ST190 (late fwd-model I suppose) 5 speed box. It runs macpherson struts all round and as you have said has been stretched a bit, apparently it is about 100mm wider and 100mm longer.
The chassis is a complete spaceframe deal, with fibreglass panels. According to the article, on 18psi boost it put out 310 hp at the front wheels, but it usually runs at the track with 25psi. 15inch TSW wheels, dunlop slicks. S4 RX7 front brakes, Suzuki GSX 1100 rears. Thats about it really.
The article is in the current issue of 'Performance Buldups' if anyone is interested. There is a red holden ute doing a burnout on the cover but there is actually some good content in this mag. It has gone down hill of late though. They featured the whole build of the 'redback spyder' which was at the motor show. Awesome car, if a bit on the ugly side.
Anyway, hope this helps.
madmorrie.
PostPosted: Sun Feb 18, 2007 8:33 am
i saw this at the drags a little while ago. morris with a 13b ( if i remember correctly)
then there was also this. bmw space frame with quad rotor
PostPosted: Tue Feb 20, 2007 3:07 pm
I remember seeing a photo of a 323 with a rotary in it using either the 323 gearbox, same as whats in a laser. I've added some pics of them. One of the pics is just one i have photoshopped into a mini to get a rough idea of size.
PostPosted: Tue Feb 20, 2007 5:16 pm
lol... nice photoshopping, but I don't know about the scale! :D
Poeee, how wide is the 323 engine bay?
PostPosted: Tue Feb 20, 2007 6:20 pm
i read that the guy in nz widened the whole car. That is freaking ridiculous. Looks nice and chubby though
DAVIDIAN
PostPosted: Tue Feb 20, 2007 9:22 pm
Damn!
I didn't know that photoshopped conversions counted!!!!
I actually finished mine months ago. Heres my 4AGE 20valve conversion into my Morris 1100...
PostPosted: Wed Feb 21, 2007 6:48 am
mad morrie
how is your conversion going?
I havent seen any updates of your site sinve october i think
Hope it is going well as that will be an awesome vehicle when complete.
DAVID
 Post subject: progress
PostPosted: Wed Feb 21, 2007 10:51 pm
David
There has been very little to report of late I'm afraid. But cause you asked I went out and took a pic of the jig, and then photoshopped it so you can see whats happening, and did a quick update. Will have to dig around and find my old thread to post this properly.
http://www.counterfeitimage.com/morris/project.htm
Cheers, and thanks for the interest.
Madmorrie
PostPosted: Thu Mar 08, 2007 10:33 pm
don't you find it funny that the only pictures of a rotary mini are sponsored by kelford cams. last time I looked rotary's didn't need cams
anyhtings possible in the land of the long white cloud
and a few conversions:
13B Extend in a 1600
PostPosted: Sat Mar 10, 2007 11:17 pm
good point!! ROFL... in the picture with the truck it doesn't have that sticker, maybe they realised the irony
