It is currently Sun Jul 20, 2025 1:31 pm
PostPosted: Fri Nov 26, 2004 11:58 pm
:shock: well im not sure about this mini but i think it is 4WD :shock:
i like chicken
PostPosted: Sat Nov 27, 2004 8:32 am
:oops: I think I just creamed myself.
where do I get one of THOSE..!!!
PostPosted: Sat Nov 27, 2004 10:24 am
there was a factory (Special Tuning) 4WD clubby that was used for motorsport in the UK. It was an 8-port 1293 and had a locked dif so it was no good on tarmac. Apparently it was unbeatable in "autocross" events
its pretty bloody ugly though
play 3d car games for free
PostPosted: Sat Nov 27, 2004 2:18 pm
Well i have all the ingredients... the wheel spacing is supprisingly close, but youd want some BIG flares.. funny as Danimim was asking if it could be done a few days ago and i ran the tape measure over the 2 and thought hmmmmmmmmmmmmm
PS wouldnt do that to dani's mini
PostPosted: Sat Nov 27, 2004 3:53 pm
I've had thought of doing this before, but I was going to look at getting hold of one of those 4wd moke concept cars, and making duplicates of the drivetrain through work. The other option is to drop a 4wd lancer system in there (Mmmm, 250+ Kw) but you'd never get the car to look stock.
PostPosted: Sat Nov 27, 2004 4:08 pm
lancer'd never go in.... too big, but I keep saying it - I'm doing one right now with a honda :P
the factory clubby was in MiniWorld a while back, and it looked like a stock clubbie, so yea, pretty ugly - it was in a moke until the competitions director saw a 4wd capri killing in autocrosses.... it wasn't a locked diff, there was no center diff meaning the 100% of the drive goes front and back so there isn't a difference in the wheel speed which is required when turning, you break diffs and axles otherwise..... they could actually get around that now using a viscous coupling like the honda I am doing, it works when the back and front wheels are rotating at different speeds - it uses silicon oil that increases viscosity under heat and there are plates which run inside it, when the oil heats up it binds the plates - therefore 4wd, but under normal conditions it's only fwd. When I was test driving the donor car before I wrecked it, I tried to do a handbrake turn, and it locked the front wheels - I thought "oh, the handbrake is on the front wheels like a subaru", but it wasn't, it was on the back wheels and the viscous coupling had locked up.
getting hold of a 4wd concept car would be impossible, but I know a guy who knows a guy who bought 10-odd sets from BMC in the 60's after the project was cancelled - must give him a call and think about adding the viscous coupling
PostPosted: Sat Nov 27, 2004 6:49 pm
yeah locked diff/no diff....u know what i meant :P :wink:
PostPosted: Mon Nov 29, 2004 8:26 pm
Here's the pic's i took on the way to Canberra..
Boots pretty sad still.. Its in the smash repairs now.
Colant leek all fixed (thanks Mike)
Smiles
Bara
PostPosted: Mon Nov 29, 2004 8:44 pm
:shock: you mean to tell me that I cant have a flip front in Sydney, but that guy can drive around in that in Canberra..!!??
:evil: where is the justice..!!!
PostPosted: Tue Nov 30, 2004 8:11 am
Moster truck MIni's....Love the Van (of Course)
Marcello your not going to do this to Mo are y :?
PostPosted: Tue Nov 30, 2004 8:17 am
it's NSW rego! maybe it's an old build-up. I wonder if it's registered as a suzuki or as a mini....
 Post subject: Moke Quadra
PostPosted: Tue Nov 30, 2004 10:33 am
there is a Quadra Moke webpage.
http://www.geocities.com/MotorCity/Fact ... a_frme.htm
The quadra uses a modified diff on a standard 1275?? and gearbox to take drive to the back wheels and uses a dog clutch arangement to engage 4wd,
normal operation seems to be front wheel drive.
Apparently there are only two. :(
PostPosted: Tue Nov 30, 2004 11:33 am
Smiles
Bara
those pics are at phesants nest :D
lookin for another clubby
 Post subject: No Way
PostPosted: Tue Nov 30, 2004 11:55 am
There's no way that'd get registered in Canberra. I'm pretty sceptical about the Starlet conversion let alon that...If he got it registered along time ago and has kept it registered since then he probably didn't have to confront alot of the more modern ADR's...
PostPosted: Tue Nov 30, 2004 12:29 pm
That is bloody nice i would get a lot of looks on the road more then what we get inour minis.
There is a Guy in Brisband putting a round nose van on a Suie Chasis with all the Suzie running gear and I think Motor.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
