It is currently Wed Aug 20, 2025 12:23 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Wed Mar 07, 2007 10:25 am
theres a method on IME (http://www.ime.org.uk/) for removing rear shocks without removing tank. Cut a hole large enough to fit your arm and spanner in the rear seat panel in line with the shocker. Concerns the structure of the car came into it, i dont think most people want to cut holes anyway :).
Try putting lots of pressure into tilting the tank backwards (lifting upwards from drain hole position). I few sharp hard shunts. i think thats how i do it.
goodluck :)
PostPosted: Wed Mar 07, 2007 10:37 am
Resident Test Pilot
Boot now full of fuel. Good thing battery on garage floor.
Matt now extremely pissed off
For Sale: 2 x as new rear shocks
PostPosted: Wed Mar 07, 2007 10:41 am
Yes , good thing the battery is on the garage floor . How did you get the boot full of fuel though , wasn't the drain plug over the opening in the boot floor ?
PostPosted: Wed Mar 07, 2007 10:43 am
Don't panic matt.
When I removed my fuel tank last time out of the LS, the fuel line broke and I had petrol all over the place.. Just wipe all the petrol up, leave the boot open for awhile and all will be good.
I put in a new fuel line and left it a lot longer so that the tank can be moved without pulling the line off the bottom of the tank...
PostPosted: Wed Mar 07, 2007 10:46 am
Resident Test Pilot
fuel line came off the back of the tank.
Seriously not going to buy a jerry can just to change a shock. It would cost me less to just let it piss out over the floor
PostPosted: Wed Mar 07, 2007 12:51 pm
Matt.....first time I ever removed a Mini petrol tank I forgot to:
1. Drain it, and
2. Take off the rear fuel line.
When I tried to yank it out, the line came off and deposited a tank of petrol into my boot, which was rusty and ran through the holes onto my new paving! :shock: :lol:
Happens to us all!
PostPosted: Wed Mar 07, 2007 1:18 pm
Resident Test Pilot
job done.
took a lunch break and went back to it.
Taking the oportunity now to put a new rubber collar on the filler pipe so as it happens it has been worthwile.
Eventually had to take the draining plug out to get the tank out.
Now I know that the next time will be easy.
Thanks to all for help
Users browsing this forum: BIGGLES, drmini in aust and 201 guests
