sgc wrote:
Pfft... just make a hydro pump, mine cost me nix.
Every time it needs a pump up, you just saved yourself around 50 bux.
Sounds like the beginnings of another howto
Seriously, I'd be interested knowing what you've got there...
There are a few simple ways, I'm sure there's a thread in ausmini somewhere.
For details on making a good a grease gun one, and fittings info, see Todd Miller's site-
http://www.austinamericausa.com/
I made mine from a Mini clutch MC, 2x Mini front brake hoses, an upturned Fiat 124 pedal box, a bit of brake pipe, and a brass valve fitting I made by soldering a brass valve cap into a 1/8 BSP fitting. Seal is the rubber ring found inside said brass valve cap.
Here's a pic-
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
