The car may not necessarily have ever had the center speedo. If it is a clubman it only ever came with the speedo in front of the driver.
Saying this, you can swap the car's instruments over but it is involved. You will need to swap the wiring loom out for the front of the car or massively butcher the one that's in there.
Buy the instrument panel you are after, and be prepared to do some wiring.
_________________ SooperDooperMiniCooperExpertEngineering
