It is currently Fri Aug 15, 2025 7:11 pm
 Post subject: TINY'S BACK
PostPosted: Thu Apr 19, 2007 7:03 pm
I is a mookenik
finally got tiny home... so happy feels good to be driving him again, juz needs a tune and a wheel alignment badly
can anyone recommend someone good in sydney so i can get it done tomorrow its really bad
other then that he prrrrs like a kitten and runs juz as good especially with the new aussie su that mini king put on for me :D
PostPosted: Thu Apr 19, 2007 7:19 pm
Jim Hunter's Suspension
9676 1544
22/ 47 Third Ave Blacktown NSW 2148
http://www.yellowpages.com.au/onlineSol ... f695&st=bn
Trust me they are good :wink:
PostPosted: Thu Apr 19, 2007 7:20 pm
Is there any body damage? If there was is that fixed or on the to-do list?
PostPosted: Thu Apr 19, 2007 7:24 pm
Good to hear he's alive again , what happened with the fuel pump problems last week ?
PostPosted: Thu Apr 19, 2007 7:30 pm
I is a mookenik
sweet ill give them a try thanks dude.. does he do dyno tuning as well as wheel alignments?
no body damage at all which im greatful for..
the pumps wiring was buggered so juz made new connections for it and new wiring, but that was the only problem the inlet manifold gaskets along with the exhurst gaskets were torn so all the fuel wasnt going in the engine anyway which was easily fixed thanks to mini king, plus he replaced the rear trailing arm cause it was bent along with a new hub and bearing plus a new gearbox mount (rear) and top mount and put the new carby on as well, runs like a dream
PostPosted: Thu Apr 19, 2007 7:43 pm
if your looking for a Dyno Before the Dyno Day
Contact Greig at Mini Classic
9874 8848
2/27 Hope Street Ermington :wink:
Better keep and eye out for retractable jumps set up in the roads... They can get u really airborne.
PostPosted: Thu Apr 19, 2007 7:45 pm
I is a mookenik
welll he needs to be tuned and wheel aligned so im hoping to get one place that has both so i dont need to run around cause tomorrow is the only day i can do it
PostPosted: Thu Apr 19, 2007 9:04 pm
High heel ninja
John Leffler, St George steering, punchbowl, best wheel alignments in Sydney, Leffo knows minis like the back of his hand. 9750 7650
Doogie
PostPosted: Fri Apr 20, 2007 4:20 pm
I is a mookenik
does anyone know the sets for the wheel alignment cause i might try it at work tomorrow, ive got the wheel alignment set there so i may as well try it otherwise im stuffed for a while
Users browsing this forum: No registered users and 358 guests
