It is currently Wed Jul 23, 2025 12:32 am
PostPosted: Sat Apr 28, 2007 9:01 am
So I will let down the system, change the bump stops, and replace fluid.
Should I change dispacer units front to rear? Shouldnt be to hard cause brakes are going to be swapped over so can do it at the same time?
Thanks, steve
PostPosted: Sat Apr 28, 2007 9:08 am
Thanks, steve
To do that you will need to remove the top arms at the front.
I've never felt the need...
Easier to just put a thick washer between the front knuckle ball and the strut. :wink:
PostPosted: Sat Apr 28, 2007 12:49 pm
check the front knuckles. Maybe they have worn through the nylon cup.
PostPosted: Sat Apr 28, 2007 3:45 pm
Will do, will also get some spacers for it aswell. All I will do is depress the system, swap the front cups, add desired spacers and pump up, and hope for the best :D
