It is currently Mon Jul 21, 2025 11:09 am
 Post subject: tyre pressures
PostPosted: Wed May 02, 2007 9:37 pm
I is a mookenik
i know this is gonna sound stupid coming from a tyre fitter/mechanic but i was reading my mini manual today and noticed it say to put 28 psi in the front and 26 on the back... usually from what ive been taught on a normal size car u put 32-36
i dont know what to put in, if i put 34 it will make the tyres to hard and bouncey if there to soft they will wear badly on the sides...what does every one recommend?
PostPosted: Wed May 02, 2007 9:39 pm
the fronts need 2 psi more as the weight is there.
32-36psi is too much unless racing.
I run 30F, 28R, on 165/70-10s. They wear even. (Yoko A008s)
PostPosted: Wed May 02, 2007 9:41 pm
I is a mookenik
sweet thanks for that
PostPosted: Wed May 02, 2007 9:47 pm
Run 50 for the dyno on saturday! :wink:
Lillee - 1969 Morris Mini K
PostPosted: Wed May 02, 2007 9:48 pm
I is a mookenik
LOL yeah and blow them up at the same time
PostPosted: Wed May 02, 2007 9:50 pm
No they will pump them to 50 for each car to run on the dyno...
PostPosted: Wed May 02, 2007 9:55 pm
I is a mookenik
LOL cool
PostPosted: Thu May 03, 2007 6:18 am
They do it at the Dyno so don't put your Pressure up for it. They don't always deflate them down so I take my Pressure gauge with me to put them back to the correct pressure again.
I think its also in the 40's chong going by memmory
PostPosted: Thu May 03, 2007 6:45 am
No Jim it was 50psi at MRC last time. :wink:
PostPosted: Thu May 03, 2007 6:59 am
same here...
was told 28f 26r for best grip, but i like to hang it out a bit.... :oops:
PostPosted: Thu May 03, 2007 7:39 am
Yeah Jim i was going to say bring a pressure gauge :wink:
PostPosted: Thu May 03, 2007 11:35 am
I want to have Al's babies
Would that be the same for 165/70-12s, Doc? Currently i run 32 - 32 after i learnt. MUCH better than the 36 - 36 i used to do! :lol:
PostPosted: Thu May 03, 2007 5:31 pm
Ian
Try 36/34 front and 32 rear - see how that feels - the rear is a little lighter and doesn't need as much pressure as the front.
PostPosted: Thu May 03, 2007 5:42 pm
Cheers, Mike. Shall do. :)
PostPosted: Thu May 03, 2007 7:44 pm
Yep Will Do
:wink:
Users browsing this forum: BrisbaneMini and 87 guests
