It is currently Mon Aug 11, 2025 11:29 pm
 Post subject: Tacho
PostPosted: Mon May 07, 2007 11:59 am
I got a new wiring loom for my mini and it has a tacho loop on it, so i disconnected the join near the label (bullet connections thru a joiner) and wired my tacho (or multimeter with tacho function) in between, now when i start the car as soon as it starts it stalls, then when i connect the loop back together it starts fine.
 Post subject: re: tacho
PostPosted: Mon May 07, 2007 12:00 pm
Is this on an electronic or standard points dissy?
PostPosted: Mon May 07, 2007 5:11 pm
Standard points Dizzy
PostPosted: Mon May 07, 2007 5:17 pm
Is it a loop for an inductive tacho?
PostPosted: Mon May 07, 2007 7:07 pm
That would be my guess too!
The old Smiths tacho worked be running the wire from the points to the coil via the tacho where it picked up the pulse from the wire.
So the current runs all the way from the dizzy to the dash and back to the coil.
It is a good place to fit a cut off switch. :wink:
PostPosted: Mon May 07, 2007 7:34 pm
It would be a perfect place for that.
So basically i need to run new wires for my tacho, i have a new VDO Hertiage Gold tacho.
PostPosted: Mon May 07, 2007 8:56 pm
You can still use the same loom with the ignition lead connected through, just have to get a pulse lead from the coil back to the tacho.
Below is how the earlier impulse tachos were wired in the clubmans.
PostPosted: Tue May 08, 2007 5:36 pm
Thanks Every one for your help.
WOW 64 cooper thats an old document, march 1963 i see still in good nick.
Users browsing this forum: Bing [Bot] and 252 guests
