It is currently Sat Aug 02, 2025 2:44 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri May 11, 2007 10:47 am
I have a vague recollection "competition" hydro fluid was once available which made the ride in hydro cars harder, but improved the handling. I imagine it is NLA.
No doubt others more knowlegable, older or wiser can comment.
I have thought of experimenting with the viscosity of the fluid (adding more ethelene glycol perhaps?) to replicate the competition fluid, but it would probably involve to much trial & error and life is too short :?
PostPosted: Fri May 11, 2007 11:44 am
I use a 50/50 mix of pure ethylene glycol and distilled water as a hydro fluid. A little more viscous than standard, and it works well.
I have heard some use 100% EG, and it seems to work for them.
Hydro handling is good. Try adjustable suspension arms, and good tyres if you really want to make a difference!
Matt
PostPosted: Fri May 11, 2007 11:46 am
Hi Matt,
Can you advise where you get your EG from?
Thanks
peter
PostPosted: Fri May 11, 2007 11:57 am
AEG163job wrote:
Hi Matt,
Thanks
peter
If you look in the auto parts stores you can find a coolant concentrate that is about 1200grams/litre EG. It is 99.9% EG, with just the bittering agent required by law (as it is sweet tasting but quite poisonous) added.
Might have the bottle at home somewhere, will have a look. Methinks I binned it tho. Was around $35 for a 5 litre bottle, and may have been 'tectalloy' brand from memory.
PostPosted: Fri May 11, 2007 12:13 pm
Is that why the coolant I got recently both looked like lime cordial, but also smelt like it? Didn't try the taste test but I was tempted. :)
PostPosted: Fri May 11, 2007 1:24 pm
Thanks guys. Yeah, I can see the dangers with the green colour.
Getting the child-proof top off may be a challenge for me though........................ :lol: :lol: :lol:
PostPosted: Fri May 11, 2007 5:30 pm
So what are you trying to achieve with thicker fluid?
Thicker fluid will not increase the spring rate. (Hydro uses a rubber spring)
It will increase the damper rate provided that the original damper valves have not crumbled into grit. (When you drain oil hydro fluid you will find a lot of black granules that were once the damper valves) :shock:
External shocks will give the same result as thicker fluid.
PostPosted: Fri May 11, 2007 5:42 pm
Basically, a firmer ride. I want my deluxe project to ride like an S, but have no S displacers. Not interested in rubber cones.
I thought of your suggestion -shockers, but unsure what the effect of chucking the rear helper springs would be :?
So being basically a very lazy person, I thought changing to thicker viscosity would do the trick.
PostPosted: Fri May 11, 2007 5:52 pm
S displacers had thicker rubber springs and different damping valves. After all this time a standard spring will probably be as hard as the original S one!
You must keep the helper springs on the rear. You only need to fit shocks to the front.
PostPosted: Fri May 11, 2007 5:56 pm
Ok, cheers
PostPosted: Fri May 11, 2007 7:11 pm
Give Ash some flowers Nick .
I've had people come up to me and car shows and tell me not to change the hydro cause they changed their car over when it was working perfectly fine - they changed to dry for better handling.
I think it handles fine and my bags don't leak or anything and consistantly holds pressure. I'm not going to change to dry unless there isn't a single useable hydro bag left in the country.
Don't think the individual little valves on each bag would actually do anything apart from add more weight.
<edit> Ask yourself what all the monte carlo winners were running :idea: From memory I think it was hydro :!:
PostPosted: Fri May 11, 2007 7:39 pm
I prefer hydro so much over dry, the wife's `77 Clubby van is going wet when rebuilt. Will have 1412 stroker, just for fun.:lol: 8)
BTW I find old hydro bags don't sag as much as old rubber cones. And if one ever leaks, meh... I got spare ones.:wink:
PostPosted: Fri May 11, 2007 9:17 pm
can somebody please explain what hydro suspention is?
PostPosted: Fri May 11, 2007 9:32 pm
Early Minis had rubber cone suspension.
From 1965 (in Oz) they fitted hydrolastic suspension instead, on most models except 850 and vans.
These use a displacer at each corner. Imagine a rubber cone with a hollow fluid bag inside it, between it and the suspension arms.
These are filled with a water/alcohol mixture, and are pressurised to nearly 300psi. The front displacers are connected to the rear, on each side.
As the front wheels go over a bump, fluid is displaced to the rear, which causes the rear of the car to rise at the same time. This maintains the car pretty level, where in a rubber cone Mini it would pitch fore and aft.
Cooper S here all had hydro until the entire model run ended, likewise our Clubman GT.
Around 1973 Minis all went back to rubber cones, Leyland wanted to save money.
I can go over local road speed humps in mine easy at 50KMH, the car just floats a little. Do this in our dry car, with Koni shocks, and you will nearly lose your brekky. :lol:
PostPosted: Fri May 11, 2007 9:45 pm
similar to a Citroen suspention setup?
