It is currently Wed Aug 20, 2025 4:31 am
PostPosted: Sat May 12, 2007 6:26 pm
Slow-Po
I was pulling bits off my moke today and found the following. Shouldn't the fact the earth isn't bolted down be causing me grief? :?
PostPosted: Sat May 12, 2007 6:27 pm
Its not good, but the engine can be grounded through other items..... throttle cable/accel cable. But all the other items are NOT designed to handle any current.
PostPosted: Sat May 12, 2007 6:28 pm
There's lots of other earthing points, but the strap is probably the best point... it's very direct.
it will eventually, unless there's a second one connected. undo nearest flywheel cover bolt, attch and do it up. solved :wink:
PostPosted: Sat May 12, 2007 6:29 pm
Slow-Po
Thanks guys. It's not going anywhere for a while, and I'll get bolted down before it does. 8)
PostPosted: Sat May 12, 2007 7:04 pm
When you do - polish both surfaces with coarse emery or a file so there is good metal to metal contact
In fact, its not a bad idea every twelve months or so to re-establish all the metal to metal contacts on a car. The givaway sign that its due is a yellowing of the lights.
PostPosted: Sat May 12, 2007 7:07 pm
Slow-Po
Thanks for the tip Mike, will do as suggested.
Look what else I found whilst I was under there, I don't know much, but I know that doesn't look right. Looks like dental floss holding it together. :lol:
PostPosted: Sat May 12, 2007 7:22 pm
Good time to fit 2 of these....
PostPosted: Sat May 12, 2007 7:25 pm
Or one of these......
PostPosted: Sat May 12, 2007 7:27 pm
Or just get ur self one of these......
PostPosted: Sat May 12, 2007 7:30 pm
Slow-Po
Agreed, what's the part called?
PostPosted: Sat May 12, 2007 7:44 pm
http://www.minispares.com/Product.aspx?pid=35285
PostPosted: Sat May 12, 2007 7:47 pm
Slow-Po
Thanks mate. 8)
PostPosted: Sat May 12, 2007 9:18 pm
Cotton reel rubber mounts can be had from Blackwoods and the like any day of the week if there's one close by, they're used a lot in industry as well.
PostPosted: Sat May 12, 2007 10:03 pm
Or any exhaust place (except they'll have metric threads)
Users browsing this forum: No registered users and 490 guests
