It is currently Sun Jul 27, 2025 1:11 pm
PostPosted: Thu May 24, 2007 10:16 pm
How do you guys fix them? Ive heard about some special paste that melts the paint and goes into scratches to fill them up etc...I recently put on my wipers and they were stopped in the upward position so when i tested them they went down...and scratched my car to bare metal, luckily in 2 small spots and not on the bonnet :oops:
PostPosted: Fri May 25, 2007 12:52 am
get some of ur original paint and brushtouch it, being 2 pack (i assume)
its not the easies t stuff to hide scratches
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Fri May 25, 2007 12:54 am
let the lawyers sort it out....
"The Hanra Method"
PostPosted: Fri May 25, 2007 1:16 am
"The Hanra Method"
its proven and works!!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Fri May 25, 2007 4:04 pm
hehe, what if its MY FAULT!!!!
I will try to fix it using original paint, being pearl metallic it will be hard to hide :(
PostPosted: Fri May 25, 2007 6:27 pm
Give Ash some flowers Nick .
That's the worst thing about peal and metallic paint. There impossible to touch up. The only way to really fix it is to respray it. The pearl will only look good once it is all applied at once.
Make sure you do touch it up though - will look better than a big scratch plus it won't rust either.
PostPosted: Fri May 25, 2007 6:35 pm
"The Hanra Method"
F*ck YEAH!
Hang on... I represented myself! But did seek legal advice from my Uncle who is a Barrister.
Users browsing this forum: Bing [Bot] and 85 guests
