It is currently Sat Jul 19, 2025 9:04 am
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon May 28, 2007 5:05 pm
mick try putting your mini in zero that might be better
PostPosted: Mon May 28, 2007 5:27 pm
Only if you want to change it's DNA , you might turn it into an 850 or a clubbie .
http://news.ninemsn.com.au/article.aspx?id=269520
PostPosted: Mon May 28, 2007 5:45 pm
the 850 would be good but i cant comment on the the other
PostPosted: Mon May 28, 2007 5:56 pm
Location: hoxton park,sydney a place where our council bins are so small you couldn't bath a baby in them!!
i can't help to wade in here
i am a coke addict i drink at least 2 litres a day (the cheap stuff) i have used it for almost everything
believe it or not though the one 101 use that not many other people have used it for is lead acid battery rejuvination when your car battery dies or or stranded somwhere with a dead battery and happen to have a few litres of coke handy top up the battery with it...
it'll suprise you .....
or if you have a battery that is stuffed just fill it with coke let it sit a while and then re fill it with battery acid...
why does everyone want a Cooper S when you ca have a better Clubby
PostPosted: Mon May 28, 2007 7:09 pm
I is a mookenik
hmmm insteresting fact!! i might try it, and al so u deliver coke ay wat would happen if some feel off the back of ur truck and into my car boot lol
PostPosted: Mon May 28, 2007 8:17 pm
Slow-Po
Mythbusters just tested cola in the radiator in the event of running out of coolant, and it came back as "plausible".
They also punctured a radiator, and test if they could seal it by putting a fresh egg into the radiator. It worked and it sealed the leak. :o :)
PostPosted: Mon May 28, 2007 8:33 pm
Coke has phosphoric acid in it and that is what gets rid of the rust - same as the rust converters on the market. As for acid and your stomach - the stomach secretes enough Hydrochloric Acid (stronger than Phosphoric) after a meal to dissolve a steel plate 3 feet square and 1 inch thick.
You feel hungry after drinking coke (or any sugar laden drink/food) because the body over secretes insulin to cope with the sugar rush and the rebound makes you feel hungry - so you eat more - and you have more rebound - so you eat more - get the picture. This leads to Type 2 diabetes ( the body can't produce insulin for ever) and obesity. You are better off eating protein bars (check the carbohydrate(sugar) levels) and drinking water - a lot of thirst is felt as hunger so drinking water stops the hunger.
David L
PostPosted: Mon May 28, 2007 8:39 pm
[quote="Wombat"] the stomach secretes enough Hydrochloric Acid (stronger than Phosphoric) after a meal to dissolve a steel plate 3 feet square and 1 inch thick. [\quote]
You have obviously eaten my mothers cooking
PostPosted: Mon May 28, 2007 11:09 pm
coke rots ur teeth and your brain.
the only time i drink the horrendus stuff is when it is mixed with jimmy. oh then it is a glorious drink to be enjoyed by all.
PostPosted: Tue May 29, 2007 12:20 am
Just don't eat Mentos with your Coke!
http://www.youtube.com/watch?v=YNgl6z5Z7k4&mode=related&search=
PostPosted: Tue May 29, 2007 9:12 am
mmmm coke...
PostPosted: Wed May 30, 2007 12:22 am
what a great experiment speedy.
Did you wear a white lab coat when you untook the experiment :)
