It is currently Sat Jul 19, 2025 11:07 pm
PostPosted: Sat Jun 02, 2007 1:31 pm
I'm surprised they even mentioned moke as everyone else only ever uses cooper to describe mini bits ...
http://cgi.ebay.com.au/MINI-MOKE-COOPER ... dZViewItem
PostPosted: Sat Jun 02, 2007 3:43 pm
Crank looks a little Rusty
PostPosted: Sun Jun 03, 2007 5:36 pm
Suit rebuild?
Suit recycling, i'd say....
Stripped 998's dont sell. Been there, tried that.
PostPosted: Sun Jun 03, 2007 5:58 pm
if anyone has a spare beauty of a 998cc block lying around let me know though.
PostPosted: Sun Jun 03, 2007 6:02 pm
I've got 5..... ranging from standard bore to +.060 .... and i'd bet i'm not the only one.
PostPosted: Sun Jun 03, 2007 6:07 pm
How good or bad does it have to be Andrew , might have one needing a rebuild but can't remember for certain .
PostPosted: Mon Jun 04, 2007 8:19 pm
i wouldn't mind a great standard 998cc block, but if i have to bore it out it'd be okay to so long as i didn't have to bore it out to far.
are you able to bore one out enough where you only have to change the rings and not the whole piston? or is it only whole piston bores allowed?
i guess this should be moved to a series mods section
PostPosted: Mon Jun 04, 2007 9:08 pm
Rings suit the piston size. If you rebore to next size you fit oversize pistons and rings. These are not much more than a set of rings alone. I got 1098 +.040" Hypatecs for $159, rings included. 998s would be similar.
