It is currently Sun Jul 20, 2025 2:07 pm
 Post subject: Mk1 Cooper S gears
PostPosted: Wed Jun 13, 2007 1:26 pm
Hi guys,
Which gear could one count the teeth of to quickly identify a Mk1 Cooper S (22G333) gear set? Is it 1st gear and how many teeth?
Regards
Al
PostPosted: Wed Jun 13, 2007 2:12 pm
18, isn't it?
PostPosted: Wed Jun 13, 2007 2:29 pm
18, isn't it?
For the Mk2 4 synchro boxes it sure is 18 on the first motion shaft coming into the box.
Don't know about Mk1 boxes however...
PostPosted: Wed Jun 13, 2007 2:37 pm
ah... mk1..
that's my addention to tetail
PostPosted: Wed Jun 13, 2007 5:30 pm
Mk1 Cooper S 1st motion shaft has 20 teeth. Deluxe and 850 have 19T. :wink:
S Cluster gear should have 22G1100 (early ones 22G232) stamped on it.
PostPosted: Wed Jun 13, 2007 6:20 pm
...or as it's also been pointed out, it can be stamped ME.
I finally found the ME stamp, it was faint and because i was looking for something else I couldn't see it.
PostPosted: Wed Jun 13, 2007 7:15 pm
This is the 3 synchro one Mick, different gear to Mk2- not sure if `ME' applied back then. BMC were pretty thorough with their stamping- before the Leyland rot set in... :lol:
PostPosted: Wed Jun 13, 2007 8:15 pm
ME is a Mk 2 Main cluster
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Wed Jun 13, 2007 8:31 pm
Didn't mk2's have the 1100 stamp?
PostPosted: Wed Jun 13, 2007 10:06 pm
no they are 22G1040. :wink:
PostPosted: Thu Jun 14, 2007 6:25 am
Thanks guys,
Your info will help me. 8)
Al
PostPosted: Thu Jun 14, 2007 7:28 am
Ahh yes as per the prior thread, my head must be full of crud this time of year, filled with useless uni knowlege prior to exams.....
pfffft....displaces essential mini part number stuff..pffffft.
PostPosted: Fri Jun 15, 2007 4:18 pm
so waht does the 22G 231 fit then??????
if the 232 is a straight cut i would presume, the 232 is helical but any ideas?
www.minicranks.com add me to your watch list and come back again soon, under construction.
PostPosted: Fri Jun 15, 2007 4:30 pm
232 is helical, early Mk1 S.
231 is 850 and 998 3 synchro, B type gears. :wink:
