It is currently Sun Jul 20, 2025 11:01 am
PostPosted: Thu Jun 14, 2007 4:40 pm
Does anybody have a simple diagram on the location of the various vacuum and pressure hoses on turbo carby. Also a diagram or photo detailing the carby and each hose purpose?
I am working on a blow through supercharger set up using a metro turbo carby.
thanks
It's not a mini, but still a bloody lot of fun! (and keeps me poor)
PostPosted: Thu Jun 14, 2007 6:15 pm
There was a thread a while back, by Poeee I think, asking about the differences between HIF44 and turbo IF44, it had a pic that did just that in it. Didn't save the pic though, sorry, you'll have to search or hope someone saved it.
PostPosted: Fri Jun 15, 2007 5:26 am
I have done a search and cant find the info
Can anyone help?
PostPosted: Fri Jun 15, 2007 8:39 am
sorry i dont have a pic now but can post one up off my car if you like.
there is 2 brass colour pipes which come out the side of the car, (if carb on engine these pipes are on the drivers side) the rear most is the fuel supply line from tank, the other pipe needs to be blocked off if you are not using the factory metro boost regulations system (better of to throw it)
ther is one pipe near the "bell" of the carb which has a hose running to the front of the carb this is a the balance pipe from float chamber to the carb venturi. then you have one very small outlet on the passerngers side front of the carb this is for vacc advance on the dizzy.
if you have the metro trubo plenum then there is one more brass pipe off it on the drivers side of the carb, this is used for the rising rate fuel pressure regulator vacuum point.
hope this helps
100% Pure A Series Turbo
PostPosted: Fri Jun 15, 2007 4:22 pm
thanks for the info - photos would be great as well.
PostPosted: Fri Jun 15, 2007 4:23 pm
the photo i mentioned above, was from http://www.turbominis.co.uk
Got to forum and searc away, I believe there might even be a sticky about it.
PostPosted: Fri Jun 15, 2007 4:29 pm
I am a member of that forum and have done a lot of searching before I posted here. I might have missed it - off to search again
I put up the same question on that forum and here is the link with the info if anybody else is interested.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=6298
