It is currently Sun Jul 20, 2025 9:17 pm
 Post subject: shocks
PostPosted: Tue Jun 19, 2007 8:05 pm
Do you need to buy lowered shocks in order to run a mini in the lowered position?
ie which ones should I buy?
These ones
Standard height
or these ones, lowered?
68 Mini
70 Moke
PostPosted: Tue Jun 19, 2007 8:41 pm
Arent Minis low enuff as it is?
1978 Leyland Mini 998LS All Original *Sally*
2002 Mini Cooper *Coopa*
PostPosted: Tue Jun 19, 2007 8:48 pm
yeah probably, but I just wanted to know if I could lower it a bit and still use the standard height shocks?
68 Mini
70 Moke
PostPosted: Tue Jun 19, 2007 8:53 pm
Slow-Po
You can, provided you don't go too extreme with the lowering. The standard ones may bottom out on big bumps, so you may want to go for the lowered ones for piece of mind. 8)
PostPosted: Tue Jun 19, 2007 9:16 pm
My cars reasonably low, and it's alright with standard Spax.
Mini's are low enough to be fine stadard but the rear tends to look silly on many, being very high off the ground, a set of rear hi los fixes this up very nicely. So IMO slight lowering at the front, a slightly more lowering at the back.
PostPosted: Tue Jun 19, 2007 9:48 pm
How could shocks lower a vehicle? they don't take up any of the weight
I can't see the photo so this could be a silly question...
Noli Illegitimi Carborundum
PostPosted: Tue Jun 19, 2007 10:14 pm
They don't , "lowered shocks" are a bit shorter than standard shocks so they don't bottom out at full compression (big bump with a really low mini) like a standard length shock would .
PostPosted: Tue Jun 19, 2007 10:16 pm
I get it now :oops:
If you read the post properly (unlike me!) it makes perfect sense.
sorry!
Users browsing this forum: Hi Roof and 74 guests
