It is currently Sat Aug 09, 2025 9:33 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Sun Jun 24, 2007 12:54 pm
so it would be fine to fill them in then
Cheers Dan
PostPosted: Sun Jun 24, 2007 1:11 pm
Why would you want to?
Someone else may want it later down the track and it IS part of a mini - why change it?
PostPosted: Sun Jun 24, 2007 1:21 pm
Mind you, has someone hacked up your heater hole?
PostPosted: Sun Jun 24, 2007 1:45 pm
yeah the old owner of the car cut a piece out of it for some reason i don't know.
i wanted to fill the holes cause i wont a clean smooth engine bay and there not used for anything important so why not. i don't plan on selling the car if i do it wont be for many years. plus the rest of the car has been given the smooth clean look so why leave the engine bay.
Cheers Dan
PostPosted: Sun Jun 24, 2007 2:52 pm
Location: Woodside, Hahndorf and Mount Barker South Australia
just an idea (remove more holes) delete the interior heater and use an old/new hair drier.......no hoses through the firewall and you will have hot air blowing on to the windscreen so your states rta will be kept happy.........
people say keep ya friends close and you enemies closer BAH I say keep your friends close and your enemies at maximum effective range.
PostPosted: Sun Jun 24, 2007 8:10 pm
Unless you lengthen the wiring and put it through a grommet you will have fun fitting the binnacle.
It's a good mod once done- on Barney I can sit in the car and take off the whole Mk2 S binnacle, unscrew speedo cable and wiring, oil pipe, the lot. I use an early Clubby speedo cable to allow this. :wink:
PostPosted: Sun Jun 24, 2007 8:14 pm
Example of the factory rotodip process..
http://www.users.tpg.com.au/ken__lee/MiniStuff/RotoDip_0001.wmv
About 2mb borrowed from http://www.britishpathe.com "Wizardry on wheels" reel 1257_01
:lol:
