It is currently Wed Aug 06, 2025 11:49 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Tue Jul 10, 2007 9:25 pm
rumour has it there might be a truck going up that way soon
Miniworx Centre 0883741299
Online BMW Mini Shop
"If you want rubber mounted frames, just put a rover front one in... "
I believe that they have the single tower bolt and won't fit an Aussie car anyway, is that right?
"rumour has it there might be a truck going up that way soon"
and these 'newish' minis will be welded back together and be on the road soon :) habits die hard.
PostPosted: Tue Jul 10, 2007 9:27 pm
they fit in the hydro tube hole...
even leylands have it.
only one is early 850's and coopers you need to drill out the bulkhead
PostPosted: Tue Jul 10, 2007 9:30 pm
Forum Graffiti
Hehe I'm hijacking my own thread...
How much would I be looking at for a front? an whats the go with this truck?
Sam
PostPosted: Tue Jul 10, 2007 10:35 pm
Sam
I'd like to know how much a front is too.
Dicko
PostPosted: Tue Jul 10, 2007 11:19 pm
Forum Graffiti
Oh I forgot to ask as well; When I was removing the subframe a few of the bolts decided to shear. Would it be ok to drill these out and tap to take larger high tensile bolts?
PostPosted: Wed Jul 11, 2007 6:51 am
If you are talking the rear subframe yes you can retap them to 3/8".
Use grade 5 or grade 8 bolts.
