It is currently Sun Aug 17, 2025 5:54 pm
 Post subject: Interior light wiring
PostPosted: Thu Aug 02, 2007 12:45 pm
So the wiring is now back in the deluxe, (thanks david for the loom 8) ) And hooking up the interior light I can't remember which way the wires go.
Looking at the wiring diagram just gives me a headache, any clues as to which end has the PW and which just has the P?
PW = purple with white trace, P = Purple.
Oh, I am using a clubman light as it fits.
Thaks
Matt
PostPosted: Thu Aug 02, 2007 12:50 pm
Hi Matt,
Power is permanently to the switch and the earth is provided from the courtesy switches or the mounting screw, depending on where the switch is positioned. So, connect the powered wire to the unswiitched side of the light.
Regards
Al
PostPosted: Thu Aug 02, 2007 1:17 pm
Thanks Al,
I think that means solid purple to the left side of the switch! I'll have a look and see if that makes sense, thanks!
Matthew
PostPosted: Thu Aug 02, 2007 1:32 pm
Hi Matt,
I haven't got my car here at work to check but finding the power wire shouldn't be difficult !!!!
Al
PostPosted: Thu Aug 02, 2007 1:34 pm
Purple from unswitched power to one side of globe
Other side of globe to one side of switch -AND- to purple white to courtesy (door) switches
Other side of switch to earth
PostPosted: Thu Aug 02, 2007 3:12 pm
Thanks guys,
I have it hooked up that way, it all works until I throw the switch to operate the light without using the door switches.
Then it blows the bottom fuse (35 amp!).
Any ideas what to check?
Thanks
Matt
PostPosted: Thu Aug 02, 2007 3:20 pm
Edit: the wires are arse about! Flip them around!
PostPosted: Thu Aug 02, 2007 3:23 pm
make sure you dont do it wrong(like pos to neg etc), i did in my 78 clubby and it melted the plastic base and wrecked it :evil:
PostPosted: Thu Aug 02, 2007 3:25 pm
The wires are arse about, flip them around!
(don't melt it, don't melt don't melt!!!)
PostPosted: Thu Aug 02, 2007 3:34 pm
Thanks mick, will flip the arse about wires, just got to get some more 35 amp fuses first! :lol: :roll: Battery disconnected now tho!
Matt
PostPosted: Thu Aug 02, 2007 4:06 pm
Well I gotta brand new in the packet one on the way, and no it's not the one from Ebay.....
And a spot welder...and a plasma cutter......
I met some very nice old time mini people.....but will speak more about it later.
Users browsing this forum: drmini in aust and 339 guests
