It is currently Wed Jul 30, 2025 12:54 pm
PostPosted: Fri Sep 07, 2007 8:46 pm
hey
ive seen them before on a mini but still cant find out where to get them. i drove in a rx7 s3 today with a guy who had one on and you could hear this thing wheeering away, are they unreliable or snap easy, extra stress on the brearings for w'pump or alt.
PostPosted: Fri Sep 07, 2007 8:51 pm
http://www.tweakit.net/shop/product_inf ... cts_id=430
PostPosted: Fri Sep 07, 2007 9:10 pm
so the a series will also suit the rx7
PostPosted: Fri Sep 07, 2007 9:40 pm
I personal don;t know of one on a Mini...But can't see why you would not have a trouble with it. It say its just cash for the sound thou :roll: ow and the bling 8) that you wouldn't not see much of :shock:
PostPosted: Fri Sep 07, 2007 11:10 pm
http://www.hotbricks.org.au/members/rides/simon/index.htm
I've seen this car, at the ewvent the photos were taken at, appart form the track shot. I've not heard anything about it since but I bet it would go hard (and sound awesome 8) ).
PostPosted: Sat Sep 08, 2007 1:13 am
so what does this thing do?
78 Leyland Mini - Prince
PostPosted: Sat Sep 08, 2007 8:45 am
A Gilmer drive is a wide toothed belt that is used in place of the v-belt to drive the alternator and water pump. It comes with special pulleys and generally won't fit on a Mini but may fit a Clubman.
The idea of fitting a toothed belt is a good one as it should be more efficient than a v-belt. The trouble with the Gilmer is that is it really too wide and probably loses any efficiency advantage.
The other problem is that most people fit a Gilmer drive to get the sound of a blower. To do this you must really tighten the belt, this destroys bearings in the alternator & water pump, the first to go will be the alternator generally.
There are of course proper toothed belts available for the Mini, I have one fitted from Mini Spares. This doesn't make any noise (as far as I can tell, mind you everything else is pretty noisy) and relatively reliable. It only has a 12mm wide belt, most Gilmers are about 40mm or more.
Regards
Daniel
PostPosted: Sat Sep 08, 2007 9:07 am
my blower doesnt make any noise that i can discern
i guess the whine on the binis is just wank and bling
PostPosted: Sat Sep 08, 2007 9:20 am
i guess it depends on how fast the blower is running so with a smaller pully and more boost it might whine more.
 Post subject: Jimmy Gilmer
PostPosted: Sat Sep 08, 2007 9:59 am
Would look good, sound good and provide positive non-slip drive but what happens if you run a bearing in an alternator or a water pump (not unheard of!!) and either of them seizes or nips up....what happens to the belt??? (I'm sure it wouldn't be pretty :oops: )
But...if you are confident with the reliability of both items....well go for it :idea: :D
PostPosted: Sat Sep 08, 2007 11:13 am
When the SC'er on the rolla was going flat out at 11psi you could REALLY hear it. It would actually drown out the exhaust.
No more Minis!......For now.
PostPosted: Sat Sep 08, 2007 11:48 am
My SC makes big whine noise when boosting up, I thought that was normal?
It sounds cool from outside the car, so I've been told. It's very noisy inside the car, along with the ram tube carby noise it drowns the exhaust out completely. I prefer the turbo spooling noise, but you get what you get. :lol: It's not about noise but about performance.
PostPosted: Sat Sep 08, 2007 1:06 pm
By blower I meant ala 14/71 variety, not an oversize air pump that we use on Minis - Go and have a look at a top fuel dragster and you'll see what I mean. The following pic shows a slight helix in the tooth profile to make it stronger with unintentional benefit of less noise.
Daniel
Users browsing this forum: drmini in aust and 105 guests
