It is currently Fri Aug 15, 2025 2:08 am
PostPosted: Mon Sep 17, 2007 4:03 pm
G'day All,
I'm toying with the idea of pulling the CV's apart on the resto and replacing the balls as I believe this is the only part they replace if the cage isn't damaged from what I pick up.
I realise how cheap they are to replace these days, but thought it might introduce some colour into their refurbishment.
Any thoughts?
PostPosted: Mon Sep 17, 2007 4:40 pm
Contrary to popular belief it's the splines that get worn on S CVs, not so much the balls and tracks.
People let the big driveshaft nut get loose, then the drive flange walks around on the spline and shags that, and itself.
Try the drive flanges for fit on a new CV, and compare... you will probably find the drive flanges are toasted too. More $$$
PostPosted: Mon Sep 17, 2007 5:28 pm
Ok, so does that mean it is possible to statically test a CV for it's condition? I had always thought the only proof was in their use?
PostPosted: Mon Sep 17, 2007 5:52 pm
Yes.
My S C/Vs on HaHa have about 1mm slack at driveshaft periphery, and have done around 130,000 miles. They still don't clunk at full lock. :D I find that is usually an indication of either hard grease or lack of it.
It's been 70,000 miles since I repacked them too. maybe about time I did again.... and the wheel bearings. :lol:
PostPosted: Mon Sep 17, 2007 6:14 pm
Yeah I am doing that at the present, the calipers are done, I've blasted the muck and crap off the hubs back to bare metal, cleaned out the ball joint sockets and reassembled. Just waiting on some bearings and flanges and I'll do some reassembly. I might take the CV's and have a look.
Users browsing this forum: No registered users and 173 guests
