It is currently Mon Aug 18, 2025 7:10 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Tue Sep 18, 2007 7:45 pm
:D
Been there , done that before . It doesn't work all the time but normally does .
PostPosted: Tue Sep 18, 2007 7:47 pm
Measure the rotor diameter, S brakes are 7.5".
Or as I said, if the studs are in the drive flange not the disc rotor, they are 8.4s.
PostPosted: Tue Sep 18, 2007 8:26 pm
They are 7.5" and the studs go through both the rotor and the drive flange.
Thanks Again :D
PostPosted: Tue Sep 18, 2007 8:29 pm
The rotor is cast iron and shouldn't be welded. In fact it's illegal to weld brake parts.
If a new stud is loose in there I would buy 2 new rotors, they are not real dear. :wink:
 Post subject: Re: Success!
PostPosted: Tue Sep 18, 2007 9:27 pm
phil wrote:
Sport850's solution of pulling on the tire (I gave it a few thumps with a malet as well) worked :D - I must admit that I didn't have high hopes of success with this method.
Once I removed the stud it was obvious that this isn't the first time this has been a problem. The back of the stud had been tack welded to the hub, but this weld has since failed. Pulling on the tyre either engaged the last of the splines or made the rough edge of the weld catch and hold.
Anyway thanks for all the help.
Now where can I get new hubs and studs in or near Canberra?
And how do I tell what type of Disc brakes I have (8.4s or S brakes as mentioned by Kevin a.k.a. Dr Mini above)?.
Hi Phil...you could try Classic Motoring out at Fishwick (Anto works there I fink)....by the by...the ACT Mini Car Club meets tomorrow night in Deakin...come along and get some more advice :idea:
PostPosted: Tue Sep 18, 2007 10:39 pm
Thanks 9YaTaH,
I will check Classic Motoring out.
I have been meaning to get in contact with the ACT Mini Car Club for a while, I've had my Mini for 5 months now. I looked at the web site: 7:30pm at the Deakin Sports and Social Club... see you there :)
 Post subject: Deakin
PostPosted: Tue Sep 18, 2007 11:55 pm
phil wrote:
Thanks 9YaTaH,
Gooooooeed...or 1830 for a Bistro meal ($7 steaks or schnitzels) if you are up for it.....look for the jolly crowd with damaged knuckles :lol:
Users browsing this forum: No registered users and 139 guests
