It is currently Sat Aug 02, 2025 12:30 pm
 Post subject: Engine numbers
PostPosted: Sat Sep 22, 2007 4:41 pm
Can someone help me with determining what engine (size)
this is there is a plate over the normal numbers spot that reads
694 aaz 16900
PostPosted: Sat Sep 22, 2007 4:42 pm
is that a police number?
PostPosted: Sat Sep 22, 2007 4:46 pm
Not sure thats why im asking for help to work it out
PostPosted: Sat Sep 22, 2007 5:30 pm
Definitely NOT a Police number.
Pommie number I would say. They were the ones who used plates with engine numbers.
Could be a 694cc motor :wink:
PostPosted: Sat Sep 22, 2007 7:03 pm
that's a wierd one!!
it's fairly simple to determine the capacity from the outside... of course, just check that there isn't a tag rivetted to the back of the motor ;)
and this is assuming it's not a heavily modified motor, IE stroked, or a big bore head on a small bore or whatever, which is pretty uncommon
step 1/ is it a 'big bore' - ie 1275, 1071, 970 - you tell that by placing your thumb between the thermostat housing and the rocker cover, if it fits, then it is a big bore
step 2/ measure the stroke - get a piece of wire and poke it down one of the spark plug holes, and keep it dead vertical. Get someone turn the engine over by hand while you hold on to it, and put a mark on it (relative to the edge of the spark plug hole) where the piston is at it's highest and lowest piont. Measure between the 2 marks and there's your stroke
then refer to this page to work out which one it is:
http://en.wikipedia.org/wiki/BMC_A-Series_engine
IE a 998 will be 76.2mm (won't be a 948 as they weren't east-west)
I'm 99% sure it'll be a 998, since the plate is rivetted on, it wouldn't be an aussie motor, they didn't have many 1100's in UK, or it might be a south african motor, in which case you might be sitting on a 1071
PostPosted: Sat Sep 22, 2007 7:13 pm
Only about 1 Million of them. :wink:
PostPosted: Sat Sep 22, 2007 7:20 pm
Picky picky :D
So what were the engine numbers on the "few" 1100's ???????
Did the pomgolians ever fit 1100 motors from the factory ????
Mike
Na don,t think its a pomme number. I have a 998 cooper engine with a strange engine number. Sometimes in the case of my engine, the race tuner puts there own number on to identify their engines.
Or ritey - Classic Minis Only For Me
PostPosted: Sat Sep 22, 2007 7:27 pm
Picky picky :D
It is not an 1100 number (it is not a Mini number either)
1100s were not fitted to Minis in the UK as far as I can make out.
PostPosted: Sat Sep 22, 2007 7:36 pm
1100 engines were fitted to some Mini models in the UK, like the Mini Clubman 1100 and also the first edition Mini Sprite, I think?
Yes they were, the last of their Clubbies had 1098s. 8)
also their 1st special edition roundnose, **** rose?
PostPosted: Sat Sep 22, 2007 7:40 pm
Thats right I forgot about the late Clubbies and other specials. :cry:
PostPosted: Sat Sep 22, 2007 7:46 pm
jeez, pick on me will ya :P :lol:
PostPosted: Sat Sep 22, 2007 7:50 pm
OK! :lol:
PostPosted: Sat Sep 22, 2007 8:01 pm
WTF has how many 1098 engines were in uk Mini's got to do with the original question?
Put the flat caps away :lol:
DOZ
PS - I have no idea what the number means
