It is currently Sun Jul 20, 2025 11:43 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Tue Sep 25, 2007 8:19 pm
not bad at all, only about 10 hp down on a cooper s motor, with standard cam, exhaust and single 1.5 su
Noli Illegitimi Carborundum
PostPosted: Tue Sep 25, 2007 8:20 pm
yeah i was told by the guy i got it off that it's standard
Cheers Dan
standard late model A+ was about 62 hp I seem to remember
PostPosted: Tue Sep 25, 2007 8:24 pm
badassmini wrote:
here you go not a very good pic but you can read it.
[img][img]http://i81.photobucket.com/albums/j211/badassmini/DSC01704.jpg[/img][/img]
It is an imported motor, it has been restamped (badly)
The Cs are 0s. :wink:
12 = 1275.
H = Transverse engine.
?02 = A02, F02 or 902 :? 902 was the 1275LS motor. A02 and F02 are Metro motors.
U = ? Probably pollution gear?
H = High compression
Z = ? There should not be a letter here. :?
001503
PostPosted: Tue Sep 25, 2007 8:30 pm
morris 1100 i think you might be right between the 12H* C or 0 theres a very light outline of a 9 but so light i didn't worry about it. would this help
Cheers Dan
PostPosted: Tue Sep 25, 2007 8:32 pm
and it has a 12g1316 head on it
Cheers Dan
PostPosted: Tue Sep 25, 2007 9:42 pm
12 = 1275.
001503
Our A+ Moke Motor in Barney is 12H706AAZ so a Z was in use there... maybe.
PostPosted: Tue Sep 25, 2007 9:57 pm
same as mini I reckon.
PostPosted: Wed Sep 26, 2007 6:16 pm
This is the engine number from my 1275LS...
PostPosted: Wed Sep 26, 2007 6:28 pm
the numbers are allmost the same.
would striping the motor down and finding out wha crank and rods are in it help find out what type of motor it is
Cheers Dan
PostPosted: Wed Sep 26, 2007 6:44 pm
Comparing those two pics (thanks morris1100) it looks like you may have the original stamping, just faint after the block has been decked a little on rebuilding. I'd vote for 1275LS.
Look for the casting number on the back of the block.
Can strip down if you want but internals could be anything. Could be good, or like the last two 1275s i stripped down, could be very very bad.
Unknown motors should really be stripped and checked at a minimum before using in my amatuer opinion.
Matt
PostPosted: Wed Sep 26, 2007 7:01 pm
Yeah, it now appears to be 1275LS, in comparison.
PostPosted: Wed Sep 26, 2007 7:19 pm
I am a little concerned about the Z, I wonder if Chris Z has any engine numbers with a Z in the 1275LS register? I wonder if the Z is a Moke engine?
The low number 001503 would probably be right for a 1275LS.
PostPosted: Thu Sep 27, 2007 6:15 pm
by checking the cast number on the back what would that tell me.
Cheers Dan
Users browsing this forum: Bing [Bot] and 67 guests
