Hi Guys, (non-gender specific)
I am having problems with the box on my 998 rod change clubby. I could only find third gear the other day, fine now...
it also crunches when changing down into second... I also have a shudder in the clutch.
I have made the expensive decision to fix it, I'm going to give it a crack myself. Of course I want to put better parts in on a budget.
I'm looking at the Clutch, Diaphragm, Lighten flywheel & Gears (only the ones needed). I want to get the right combination of parts with out going overboard.
I have between $800 - $1,000 to spend.
What do you recommend?
