It is currently Tue Jul 15, 2025 1:52 pm
Post new topic Reply to topic  [ 73 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Thu Jan 06, 2005 8:57 am
isn't that where the spare goes nicho?? :?
play 3d car games for free
PostPosted: Thu Jan 06, 2005 9:02 am
Spare goes behind the passenger....
PostPosted: Thu Jan 06, 2005 9:28 am
...and slides under the upper load floor.
So if you have high-back seats without removable headrests, you have to remove the passenger seat to get the spare out... :(
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Thu Jan 06, 2005 9:32 am
Unless you can push the seat far enought forward
PostPosted: Thu Jan 06, 2005 9:48 am
You show me your's I'll shgow you mine
Mine only has the gasket on the Lid. Yep I think its the orginal going by how old it looks. It does not have the seal on the roof but the roof has been resprayed to it may have been taken off and not replaced.
One other thing theat does interest me thought, mine is rifited down and not nut and bolt like i'f seen with the others that have been posted up here. Which one was orginaly done.
PostPosted: Thu Jan 06, 2005 9:53 am
I reckon rivets were original - I've never seen bolts, and the original holes are too small for bolts
PostPosted: Thu Jan 06, 2005 10:02 am
Fez wrote:
http://home.iprimus.com.au/cjfairs/mini_van.htm
that is a very pretty little van, nice work....
I'm getting rid of my vent, I hate it - spoils that perfect flat roof
PostPosted: Thu Jan 06, 2005 11:33 am
Mine has the rivets.
SK - the vents are COOL! :D
Open the front quarter window and the vent and you get a nice flow through ventilation! Watto fitted a vent to his cl;ubby van for this reason.
Besides, you would have weld in a patch to remove it neatly...
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Thu Jan 06, 2005 2:47 pm
Regarding the battery. Directly behind the drivers seat if I lift up the carpet and underlay on the loading floor i have a hatch that can be opened to access the battery. Its possible that this could be a modification I'm not sure on the history of that. It can also be acessed as normal by sliding it out the bottom .
1965 850 Mini Van
1972 Clubman Van
Member of SDMC
PostPosted: Thu Jan 06, 2005 3:48 pm
:shock: Not mine
PostPosted: Thu Jan 06, 2005 4:18 pm
Definitely a mod, but a sensible one. You cannot slide the batter under there as original.
Post some pics??
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
 Post subject: Travellers!
PostPosted: Thu Jan 06, 2005 4:22 pm
Post some pics??
I'm fairly sure that this is not a mod AFAIR....just typical British Engineering....I've seen this arrangement on a Traveller and was horrified :roll:
PostPosted: Thu Jan 06, 2005 6:03 pm
Travellers have the battery under the rear seat as standard. What's so horrific about it?
All vans left the factory with the battery directly behind the drivers seat, not under a cover further back. There is a metal plate that prevents the battery sliding underneath. If the battery can be slid under the load floor on this van it is definitely a mod.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Thu Jan 06, 2005 7:52 pm
I'm with bnicho, that battery cover is definitely a mod....
I like the vent for the flow through air, but I hate it for leaking, and it looks pov, plus those extra 8 or so square inches of frontal area are slowing me down :!: :!: :!:
but look, my van is fully sick with it's racing stripes
but the vent just spoils it - check this out
with the vent, ewww
and without, sweeet
although, I must admit that it is an awesome place to hang the mirror ball, especially on a sunny day when you can open the vent and the sun hits it... (note, they're NO GOOD on the rear view mirror)
here's another recommended mod for those who like to fang their vans - braces the inner arches from flexing, and gives you something to strap yer milk crate to
 Post subject: battery in a van
PostPosted: Thu Jan 06, 2005 8:13 pm
in regards to the battery, i have peered into a SUZUKI Carry once at the wreckers (the small skinny vans) and they have a battery box that has the top flush with the cargo floor. the box can be removed. it's kinda hard to explain, but next time i'll take a pic of it. i thought it was an interesting way to stow the battery in a minivan.
