It is currently Sun Jul 20, 2025 1:31 am
 Post subject: clutch
PostPosted: Thu Oct 25, 2007 1:47 am
hey gang, well mad-mk1 is running, now i have to organise the clutch, i am hoping to do taht this weekend!
now what need s doing, ima clutch noob, im pretty sure everythings there.
sorry to be so unhelpful
cheers jamie
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Thu Oct 25, 2007 7:36 am
:? Someones obviously had problems with the clutch before looking at the bent arm and adjustible rod in the slave cylinder , best get some spares on standby for when you start sorting it out as I suspect there may be some surprises . How bad is it at the moment ?
PostPosted: Thu Oct 25, 2007 10:45 am
its never been hooked up in the car, ujust hadthe whole subby put in, im just not sure where to go from here,
motors done 200ks since rebuild...
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Thu Oct 25, 2007 11:26 am
i spy with my little eye..................
Return spring has gone AWOL :shock:
Adjust according to the manual & see how you go
PostPosted: Thu Oct 25, 2007 12:11 pm
I would certainly look at buying a new clutch arm, top and bottom clevis pins and a clutch return spring. Easy to fit. I had a bent clutch arm like that in my car when I got it, I replaced it with a new one and a new clutch shuttle and fixed all of my clutch problems. Until the clutch shuttle wore out somewhat quickly - I always use unworn original items now as the new ones seem to be a bit average.
PostPosted: Thu Oct 25, 2007 3:23 pm
Yea that adjustable slave rod spells trouble..
PostPosted: Thu Oct 25, 2007 4:12 pm
I have an adjustable clutch rod on my car, I could never figure out why my clutch slowly stopped working until I realised the clutch push rod was adjusting itself shorter and shorter....
PostPosted: Thu Oct 25, 2007 8:50 pm
Location: Woodside, Hahndorf and Mount Barker South Australia
the mini clutch is self adjusting yeah?
people say keep ya friends close and you enemies closer BAH I say keep your friends close and your enemies at maximum effective range.
PostPosted: Thu Oct 25, 2007 8:53 pm
Yes, you adjust it yourself. 8)
PostPosted: Thu Oct 25, 2007 8:57 pm
ok my clutch engages when my pedal is almost to the floor..................how do u adjust the clutch......
PostPosted: Thu Oct 25, 2007 9:01 pm
Wind the clutch arm stop out, it is situated on the clutch cover. 7/16 bolt by the way and dont forget to lock it up afterwards.
Dont over adjust it though. Go a flat or two at a time.
Matt
PostPosted: Thu Oct 25, 2007 9:27 pm
and make sure there's a bit of clearance btw the stop and the clutch arm, say at least 5-10 thou :wink:
PostPosted: Mon Oct 29, 2007 11:55 pm
ok kids ima we bit lost.
i bled it, probably not well enough, but i have a we bit of clutch, but not much at all......
what do i do to g about adjusting it?
also ona nother note, it backfires every now and tehn through the carby, how can i fix this. i ahve turned the dizzy to teh radiator side, but now teh vacuum trupety thing hits the oil cooler hose, and cant go no further...
any help much appriiciated.
clutch teh most. i wnated it finished for a important thing on friday.
cheers jamie
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Tue Oct 30, 2007 12:12 am
http://www.minimania.com/web/SCatagory/CLUTCH/DisplayType/Technical%20Information/DisplayID/153/ArticleV.cfm
read
learn
michael
PostPosted: Tue Oct 30, 2007 12:39 am
i only really got teh technical bits, on why things do what they do, not really how to fix it.
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
Users browsing this forum: No registered users and 64 guests
