It is currently Sat Jul 26, 2025 8:53 pm
 Post subject: Exhaust
PostPosted: Thu Oct 25, 2007 4:04 pm
Does anybody use exhaust joint compound on the standard manifold, exhaust and flange or do you trust the exhaust without?
PostPosted: Thu Oct 25, 2007 4:07 pm
I recently installed a standard exhaust and I
had to use that red coloured exhaust sealant.
No leaks now
Felix
1966 mustang coupe 289 auto
1970 mgb roadster auto
1970 cooper S mk2
1976 mini S
1964 wolseley 24/80
http://s160.photobucket.com/albums/t173/1966mini/
PostPosted: Thu Oct 25, 2007 4:10 pm
Definitely a great idea to use sealant on any exhaust.
When I had a standard exhaust I used gasket sealant and it still use to leak after a while. I changed to extractors, no more leaks!
PostPosted: Thu Oct 25, 2007 4:15 pm
hell... even i used it.. :D
PostPosted: Thu Oct 25, 2007 4:17 pm
On a good exhaust pipe with a cast iron clamp I don't use any but with a worn pipe (flange) and the crappy pressed metal clamps I put a thin smear on the flange and on the inside of the clamp . Not a lot , just a little to help it seat and seal .
PostPosted: Thu Oct 25, 2007 4:18 pm
This space for rent
Back in the day I always used that Maniseal putty on the standard joint. The seal never lasted very long though, with the engine rocking around it'd crack and leak fumes into the car.
These days I still use it, but on the extractors.. it seals much better when the pipes are already a good slide fit.
PostPosted: Thu Oct 25, 2007 4:28 pm
i impregnate fiberglass cloth with exhaust cement, wrap it arround the joint, then put the clamp on. works good, as long as the rest of the exhaust is on good!
PostPosted: Thu Oct 25, 2007 4:32 pm
I've only had one mini that had problems with the flange leaking , all the rest were good and sealed tight . Make sure you've got the exhaust bolted tight and square to the body and manifold before you put the clamp on so there's less movement and get one of the older cast iron manifold clamps if you can .
PostPosted: Thu Oct 25, 2007 4:36 pm
This space for rent
It wouldn't have helped that the engine had ripped the top steady bar mounts off, so flapped around the engine bay like a wet fish :lol:
Made for good training in smooth throttle control :)
PostPosted: Thu Oct 25, 2007 4:43 pm
Yeah, I used Maniseal, sealed my dodgy joints due to old thrashed out exhaust flanges etc. - Also got me passed my roadworthy. :D
